27-02-2007, 11:51 AM
I'll xploit ur Territory
hard drive help
i want to buy a new hard drive of 160 gig and i have a budgetof 4000 max.
suggest a gud company,
is seagate fine?
<<XFX 680i TLi chipset>>Dual core 2.8Ghz>>2*1GbTranscend 800 hz>>8800 GTX XXX 768 Mb..GTX 260 862 Mb now GTX 280 1 Gb>>Cabbi CM 690 Nvidia SLI>>CM OEM 600w>>APC 1Kva UPS>>
03-03-2007, 01:14 AM
Re: hard drive help
I guess u shld get 250Gb hdd for ur budget...
Segate is fine go for it
_______________________________________________
One World, One People!
03-03-2007, 01:26 AM
Re: hard drive help
yeah seagate 250 gb is 3600/- (sata) and normal is 3500(IDE)
03-03-2007, 06:39 AM
Re: hard drive help
Samsung or Seagate both are fine
"UNIX is basically a simple operating system, but you have to be a genius to understand the simplicity."
-Dennis Ritchie
03-03-2007, 08:02 AM
Resident Fanatic
Re: hard drive help
Western Digital are also not Bad but check the pricing..
they hav good customer support
03-03-2007, 11:32 AM
Romeo + Lucifer = ME
Re: hard drive help
Western Digital
Sony Vaio CW26FG
Nokia E 63 + Iphone 3GS
12-03-2007, 01:52 PM
Re: hard drive help
actually i got that harddrive bt got it for 4200 as my vendor says tht transport costs are included in this.
12-03-2007, 01:58 PM
Re: hard drive help
^^ Cheating you. Got 40GB @ 2.4k with fitting!
Segate's the best. 5 yr. old 2nd hand HDD still running.
KDE on ArchLinux
12-03-2007, 03:35 PM
Re: hard drive help
Hey friend I will recommend u to go for Samsung if not possible then go for Seagate. These two brands are best.
13-03-2007, 11:35 AM
Re: hard drive help
Don't go for Western Digital Maxtor.
Western Digital hard disks are more prone to faults.
U may opt for Samsung or Seagate.
I was told this by a Hard Disk Recovery Centre personnel.
Dell Studio 1558, Intel i5 M430 @ 2.27 Ghz, 4 GB RAM, 1 GB ATI 5470 Mobility, 500 GB HDD, IDT HD Audio with Creative X-Fi MB software
13-03-2007, 12:46 PM
Re: hard drive help
^^^ WD makes one of the best HDDs.personally i've used both Seagate and WD and i find the performance of WD to be better.
13-03-2007, 05:08 PM
I Always Prefer 1080p
Re: hard drive help
Buddy correct your post
How can you get 40 GB for 2.4K ?
13-03-2007, 05:44 PM
Re: hard drive help
He must be talking about laptop hard disk. It's expensive than normal desktop hard disks.
13-03-2007, 05:47 PM
Re: hard drive help
^^ both of you
No really Desktop HDD.
KDE on ArchLinux
13-03-2007, 05:55 PM
Still Shining!
Re: hard drive help
Western Digital.
Seagate is good, but when you buy...double check if there is any unnecessary sound coming from the HD while working...
Nokia N86 8MP
13-03-2007, 06:04 PM
Re: hard drive help
^^ both of you
Then must be SCSI. Cos for that much moolah, u could get a 160-200 GB desktop IDE HDD.
13-03-2007, 06:22 PM
Re: hard drive help
NO IDE.
KDE on ArchLinux
13-03-2007, 06:57 PM
Re: hard drive help
U can go for Hitachi 250 Gb SATA2 for 2.5k. Its better than Seagate or Samsung, nd has greater value for money.
G3: XPS M1530 |
FZ 16.
