27-02-2007, 01:01 AM
Broadband disconnection
I have a dataone broadband connection. When I first switch on my modem, after about 5 minutes, connection seems sluggish and gets disconnected for 5-10 seconds. It happens every time. How can I overcome this?
27-02-2007, 01:20 AM
Re: Broadband disconnection
it happens..sometimes
to make life easy do one thing..to restart thru software
type
192.168.1.1 in yr browser..
then it ll ask pass and name.
name =admin
pass=admin
or name =admin
pass=password..
these r defalut passwords and usernames..
then search for reboot modem.and click it..
however sometimes it not open up ..so u have
restart modem physically..
hope it helps
like it then rep it.
Be like a postage stamp-stick to one thing until you get there.
27-02-2007, 05:30 AM
Nice tip I'll recommend it to one of my friends who has a similar problem...if it works definatelly repping you.
27-02-2007, 09:09 AM
Knowledge Nomad
i dont think dis is any modem problem
it may be server problem from bsnl part go call bsnl helpline and ask dem
27-02-2007, 09:15 AM
i m using airtel it even happens to me..and sometimes it is a modem prob
and sometime it is server prob..the only thing we can do ..is
as a first measure:
1)restart the modem or router..or repairing connection.
2)think something else like calling helpdesk .
27-02-2007, 09:54 AM
Host4Cheap.org
Are you using USB Modem ?? USB Modems are subject more problems than Ethernet
http://www.host4cheap.org/
27-02-2007, 10:08 AM
I'm using ethernet for broadband.
During the initial moments, connection seems sluggish. Once it restarts, everything works normal then.
27-02-2007, 10:22 AM
so yr prob solved or not.
27-02-2007, 10:26 AM
I'm not in my home now. Will check out as soon as I go home and let you know.
27-02-2007, 11:45 AM
This process will always put ur connection active and live
so u never face problem of disconnection
Follow these steps
1. Press Window key+R
2. In Run Prompt Type 'notepad'
3. type ping -t <DNS Server>
4. Press Ctrl+S
5. In file Name Dialog Box write Net.bat(or anything but extension should be .bat) also select File Type as All(*.*)
6.Now u r done when u connect ur net after connection just run this file
To know whats ur DNS server
Type ipconfig/all on command prompt
27-02-2007, 12:46 PM
Follow these steps
4. Press Ctrl+S
It keeps pinging the dns server continuously. I'll lose a lot of bandwidth if I do that.
27-02-2007, 01:01 PM
it pings only 32bytes of data how much band width u lose there buddyy
i think its negotiable
also it keeps ur connection alive
even if u r not working on net
27-02-2007, 02:16 PM
r u having limited download connection..
but yr prob is not a prob it happens with everybody..sometimes
if this prob occurs very frequenlty then there is a prob..with
the modem change it...
or
do as per my first post..
27-02-2007, 02:19 PM
well, it gets disconnected about 5 minutes after connecting and connects back again. It happens the first time i switch on the modem.
27-02-2007, 03:56 PM
just try -t(infinite) pinging for continuous connecction
i have BSNL Broadband with USB Modem and i m curently using it
27-02-2007, 04:07 PM
32 bytes per second => 2KB per minute => 120KB per hour
Not a lot of bandwidth wastage
27-02-2007, 04:08 PM
a_g = JPKN
dude, just log in to the "Modem Settings" Page (thru IE, Opera...) & goto the "ADSL Settings" under "Advanced" & see what "ADSL Modulation" you are using.
If its "G-lite" then change it to ADSL 2+. (or try experimenting with other modes)
^^this Pic shows Huawei SmartAX MT880 Modem
for many ppl the G-lite works perfectly, but for me when i changed from ADSL2+ to G-Lite i faced exactly the same problem as you do.
ASUS K53SV SX520D + BF3
27-02-2007, 04:11 PM
r u using vry limited bandwidth
i m using unlimited
27-02-2007, 04:25 PM
#19 (permalink)
i m using unlimited
I'm on Home 500 plan
__________
I'm using Multimode. Previously I was using ADSL2+. But back then my speeds were very low. After changing to MULTIMODE, my speed has increased.
Reason: Automerged Doublepost
27-02-2007, 04:29 PM
#20 (permalink)
Buddy why not go for Unlimted 900+
see u r paying
500+180 monthly rent
680 and very much thinking about bandwidth usage
go for 900+
charges
900 includes 180 monthly rent
cheers
27-02-2007, 04:35 PM
#21 (permalink)
left this forum longback
I got dataone Home 500 connxn;i feel the T1.413 is the best for me.also i updated the firmware(pls dont ask me!) to the one Jul 6 2005.yes I have Huawei SmartAX MT880 Modem
btw i get with T1.413 settings or what: 227KB/s @ max :/
27-02-2007, 04:45 PM
#22 (permalink)
a_g = JPKN
web dude  , so has this problem cropped up just now or after when you changed the modulation mode.
IMO just experiment with G-lite mode,.
& c'mon dude you're getting atleast 100+KBps then why do you bother about speed loss
27-02-2007, 04:56 PM
#23 (permalink)
This problem has surfaced after the broadband outage in Bangalore for two days. Before that, everything was normal. So I think it has got to be a problem with their server.
27-02-2007, 04:59 PM
#24 (permalink)
a_g = JPKN
hmm, i havent faced any problem like this.
i'm near "Vasnath Nagar" (Cunningham Road).
why dont you try other modes, like "praka" has T1 mode enabled.
27-02-2007, 05:25 PM
#25 (permalink)
Hmmm...That sounds reasonable. I'll give the other nodes a try today night.
