Old 26-02-2007, 10:29 PM   #1 (permalink)
LIFE Overclocked!!
pritzdj's Avatar
Exclamation PC stops in BIOS... Plz Help....
I m using AMD Athlon 2600+, 512 RAM.........
My PC facing a very typical problem........ When i start my PC then stops or freeze in the BIOS....... after pressing a reset button 4-5 times it restarts normally...... I tried by removing and reseting my CMOS Battery, but no use....
Plz help me out im in big trouble............
pritzdj is offline
Old 26-02-2007, 10:34 PM   #2 (permalink)
shantanu's Avatar
Default Re: PC stops in BIOS... Plz Help....
iopen your cabinets and check for loose connections... then take your ram out and clean the slot and RAm and then put it back... also check your SMPS.. for trouble.. how much watts your SMPS is .....
shantanu is offline
Old 26-02-2007, 10:37 PM   #3 (permalink)
LIFE Overclocked!!
pritzdj's Avatar
Post Re: PC stops in BIOS... Plz Help....
I checked for loose connection but no use....... ok i'll chk my ram out and clean the slot....... My SMPS gives my PC 400 watts..........
pritzdj is offline
Old 26-02-2007, 10:46 PM   #4 (permalink)
shantanu's Avatar
thats ebough i guess.. so did you install a new hardware... if not then take your RAM to a friend and check it in his PC or borrow a RAM and then CHeck it installing it in your PC
shantanu is offline
Old 27-02-2007, 02:39 PM   #5 (permalink)
LIFE Overclocked!!
pritzdj's Avatar
Talking Re: PC stops in BIOS... Plz Help....
Ok i'll chk that.......
__________
Thanks shantanu_webmaster it works.........
i cleaned my SMPS, now it my PC is working.
pritzdj is offline
Old 28-02-2007, 11:42 PM   #6 (permalink)
LIFE Overclocked!!
pritzdj's Avatar
thanx shantanu_webmaster...... it worked.........
pritzdj is offline
Old 28-02-2007, 11:54 PM   #7 (permalink)
shantanu's Avatar
Thats fine buddy !!! its good that it helped!!
shantanu is offline
