Old 26-02-2007, 07:37 PM   #1 (permalink)
Ðèåd Måñ Wå£KîÑG
bad_till_bones's Avatar
Question Temperature Issue....
Having an Intel D102 MotherBoard, Dual Core 2.8 Ghz processor, 1 GB RAM and 160GB SATA HDD.
Was lil worried abt the heat this PC is generating....
Played some heavy games for a while and then noted the readings with HMonitor, they were -
MainBoard - 54 degrees celsius.
CPU - 56 degrees celsius.
HDD - 41 degrees celsius.
Chassis - 1457 rpm. (Don't understood, whts this?)
Are these readings normal?
And wht shud b the standard reading for this config?
Plz also tell the max allowed?
Guys, plz help me out....
Once the game is over, the King and Pawn goes to the same box....
bad_till_bones is offline
Old 26-02-2007, 07:39 PM   #2 (permalink)
Tech Geek's Avatar
Default Re: Temperature Issue....
50's is normal.
my PC keeps showing that temp the whole day
Tech Geek is offline
Old 26-02-2007, 08:01 PM   #3 (permalink)
Coming back to life ..
it_waaznt_me's Avatar
Chasis : 1457 RPM : Fan rotation per minute .
You can use SpeedFan to monitor and control temperature of your system.
And I wait without you ...
With or without you ..
Batty = Too Busy Now !!!
it_waaznt_me is offline
Old 26-02-2007, 10:54 PM   #4 (permalink)
The Frozen Nova
casanova's Avatar
Same with me. Around 50-55 degrees. What bothers me is the noise. I think my problem is with power supply as once I had brought my friends pc to use and even it made noise at my place where as it works silently at his place. what should I do about this.
www.nerdweed.blogspot.com
casanova is offline
Old 26-02-2007, 10:59 PM   #5 (permalink)
Ðèåd Måñ Wå£KîÑG
In the above link, there is a line -
"Its main feature is that it can change fan speeds (depending on the capabilities of your sensor chip and your hardware) according to the temperatures inside your pc, thus reducing noise."
Hope this software plays safe....
Old 27-02-2007, 12:26 AM   #6 (permalink)
deathvirus_me's Avatar
Unhappy Re: Temperature Issue....
Dude , no offence but the temps do seem a bit high .. not the CPU , but particularly the Motherboard and the Harddisk ... those should be kept under 40c by all means ..
Overall the PentiumD runs quite hot , and infact ur temps are quite fine there ..
deathvirus_me is offline
Old 27-02-2007, 01:25 AM   #7 (permalink)
 Macboy
goobimama's Avatar
My pentium 4 3.0Ghz used to run at 62C when I used a normal iBall cabinet. Then I got the coolermaster and it reduced to 56C, it still is hot though (runs at around 70C when playing games or HD)
I'm like a bird... :)
goobimama is offline
Old 27-02-2007, 01:28 AM   #8 (permalink)
shashank4u's Avatar
uptu 60 there is no prob..
Be like a postage stamp-stick to one thing until you get there.
shashank4u is offline
Old 27-02-2007, 05:47 AM   #9 (permalink)
caleb's Avatar
There is nothing wrong with your system...Dual Cores run a bit more hotter than the others but it's fine and there is nothing to be alarmed about.
__________
Do nothing, your sys is fine. Dual Cores & C2D's do make noise at times depending on the stress caused by intensive programs but they are good work horses.
caleb is offline
Old 27-02-2007, 10:13 AM   #10 (permalink)
Ðèåd Måñ Wå£KîÑG
Thnx to all for ur comments....
Only one thing worries me, and tht is motherboards temperature.
Touching 60 degrees at times....
Shud it b really below 40 degree C?
Old 27-02-2007, 11:46 AM   #11 (permalink)
piyush gupta's Avatar
upto 60C its not a problem at all
piyush gupta is offline
Old 27-02-2007, 12:27 PM   #12 (permalink)
a_g = JPKN
s18000rpm's Avatar
is your CPU cabinet airy enuf or placed in well ventilated space & are the fans clean (no dust accumulation).
& btw is your PC a HP Pavilion???
my cousin bought a exactly same configed HP Pavilion Desktop.
ASUS K53SV SX520D + BF3
s18000rpm is online now
Old 27-02-2007, 02:06 PM   #13 (permalink)
Ðèåd Måñ Wå£KîÑG
Actually it is placed on a right-corner, 7-8 inches from the grnd....so the right and back side of the cabinet is towards the wall. However, both the sides have arnd 3-4 inches of gap from the wall. I think tht description is more than enough....lolz (BTW: I don't have anyother choice of keeping it elsewhere....coz the computer table is fixed).
Hope, the location is fine????
And its 2 months old PC, so fans are clean
No, it’s an assembled PC not a HP Pavilion.
Old 27-02-2007, 03:26 PM   #14 (permalink)
Tech Geek's Avatar
acctually the cpu should not be near the wall.
but it is not a trouble 4 inches gap should be enough.
Old 27-02-2007, 11:18 PM   #15 (permalink)
The Frozen Nova
casanova's Avatar
Thats what I call my comp after the model of my caninet iBall workhorse.
BTW, the noise is continuous.
casanova is offline
Old 27-02-2007, 11:27 PM   #16 (permalink)
SpeedFan is a well known software among overclockers so it shouldnt create any problem.
Old 28-02-2007, 06:53 AM   #17 (permalink)
caleb's Avatar
Is it every single day or on somdays it is continuous and other days it is not?
My sytsem also makes noise somedays even without stressing it but generally it only makes noise when it is stressed eg. video transcoding/encoding etc.
caleb is offline
Old 28-02-2007, 09:00 AM   #18 (permalink)
The Frozen Nova
casanova's Avatar
Everyday every time. At times this noise increases gradually and I know this is because of stress.
casanova is offline
Old 28-02-2007, 09:03 PM   #19 (permalink)
Hello,
I install that software on my pc, and I notice that minimum temprature of my cpu is 63 and after some it rises to 73, and there is no reason for it. this is a perodic condition that temp. get rise and down.
When temp go rise , CPU uses goes to near 100% and fan speed also rises.
I ont know why this is happening. this happens while reading a text file in notepad also.
What is this? what shoul I do now? is this risky for my pc?
I have P4 - 2.8Gz , 256 ram and 80SATA.
Help me.
neelg22 is offline
