Old 26-02-2007, 01:24 PM   #1 (permalink)
Default Is firewire faster than USB 2.0?
I have a usb 2.0 portable hdd but lately I had to copy 30-40 gb data & found that it takes good amount of time doing that, its faster but I am wondering if firewire would have done that faster than usb 2.0
I found a firewire casing (Interface: USB 2.0/ firewire COMBO) here in nehru place & I can swap the case keeping the same seagate 80gb hdd.
I am thinking if firewire is faster than I buy this casing though its quite expensive than the usb casing......................so is it worth at 1200/- for firewire?
http://www.svbinternational.com/exte...394_usb_20.htm
ranjan2001 is offline
Old 26-02-2007, 01:39 PM   #2 (permalink)
 Macboy
goobimama's Avatar
Default Re: Is firewire faster than USB 2.0?
Well technically Firewire400 (400mbps) is slower than USB2.0 (480mbps). But in the real world tests, Firewire seems to hold its own for raw speed. The difference is in the architecture so a FW drive will have a better sustained write/read speed, sometimes even 70% faster than USB2.0. And then there's Firewire800 (800mbps) which is used in high end stuff, not very commonplace (The Western Digital Pro drives come with FW800)
Not sure if its worth the extra 1200 bucks for firewire, especially since its such a low capacity hard drive...
I'm like a bird... :)
goobimama is offline
Old 26-02-2007, 01:42 PM   #3 (permalink)
shashank4u's Avatar
go for usb 2.0 ...if u got ample money then go for firewire..simple
AFAIK usb 2.0 provides gud speeds inlarge transfers.
Be like a postage stamp-stick to one thing until you get there.
shashank4u is offline
Old 26-02-2007, 02:04 PM   #4 (permalink)
The High 5 Flyer
sam9s's Avatar
Adding to what goobi said the reason Firewire is faster than USB 2.0 is....
FireWire, uses a "Peer-to-Peer" architecture in which the peripherals are intelligent and can negotiate bus conflicts to determine which device can best control a data transfer
Where as USB 2.0 uses a "Master-Slave" architecture in which the computer handles all control functions and dictates data flow between the attached peripherals and this adds additional system overhead resulting in slower data flow.
Tests have shown that Firewire is much faster than USB 2.0 in both file read and write tests.
But for convenience and compatibility between multiple computers a USB 2.0 external hard drive would probably be a better choice (since practically every computer has a USB port).
sam9s is offline
Old 26-02-2007, 07:15 PM   #5 (permalink)
I dont know how much is ample money, but from experience I have learnt that "mehanga roe ek bar , sasta roe bar bar"
So lets say I transfer 2000Gb in 1 year & save 30% of time using firewire then u can see Rs.1200 should not matter any one bcoz the time saving is huge.
__________
Any idea when is that "sometimes 70% faster" that will be a huge time saving.
__________
Sam reading ur post now I am convinced that I surly would see speed difference if I use firewire.
Any other things to consider before I go the firewire/usb 2.0 combo route?
Old 26-02-2007, 07:25 PM   #6 (permalink)
The High 5 Flyer
sam9s's Avatar
@ranjan It would depend upon your usage as well, if an external HDD would be used more for data portibility then you might consider going USB way coz as I said not evey computer you would share data with would be having an IEEE conn. So you can sacrifice speed for better portability, but if is like to keep a backup or using it with any laptop while you are on the move, go firewire way. coz in that case slow speed would probably pinch.
sam9s is offline
Old 26-02-2007, 07:35 PM   #7 (permalink)
aryayush's Avatar
Please answer three questions:
1. Does you computer have FireWire ports?
2. What is the price of the hard drive?
3. Does it have FireWire 400, 800 or both?
If it has FireWire 800 or both, it is definitely worth it to invest the extra twelve hundred bucks. I have done real world tests. Transferring seventy gigabytes using FireWire 800 took twenty-five minutes and it took one hour and twenty minutes on USB 2.0. FireWire 800 is REALLY fast.
And if you want good a good FireWire drives, the best company is LaCie. They make awesome drives. I have a 250 GB external drive from LaCie which has all the interfaces - one USB 2.0 port, one FireWire 400 and two FireWire 800 ports. Guess which one I use.
aryayush is offline
Old 26-02-2007, 08:05 PM   #8 (permalink)
Mosty Its used for transfering data from 1 location to another or 1 desktop on the move......................yes desktop not laptop.............using mojopac.
I am reviewing Mojopac trial version, which allows u to install ur softwares on a portable hdd & then it can be connected either to desktop or a laptop or any internet cafe having usb /firewire connection.
XP on C/all software on different HDD, no need to reinstall if xp crashes.
__________
Yes 2 ports on my new comp & 50% of comps I connect have firewire too, rest have usb 1.1 or 2.0
I am not buying a hard drive I already have this one is just a casing to fit any portable hdd.
I was not aware of 400/800 so now I need to check this feature too.
Old 26-02-2007, 08:08 PM   #9 (permalink)
 Macboy
goobimama's Avatar
Sad...my iMac has only FW400 ports.... Will be getting a Western Digital My Book Premium 250GB for the purpose...
Old 26-02-2007, 08:10 PM   #10 (permalink)
HELP AND SUPPORT
rakeshishere's Avatar
Chk these links out!
http://www.usb-ware.com/firewire-vs-usb.htm
http://www.digit-life.com/articles/usb20vsfirewire/
http://www.cwol.com/firewire/firewire-vs-usb.htm
rakeshishere is offline
Old 26-02-2007, 08:17 PM   #11 (permalink)
Thanks those link helped....................Sam9s already posted though the same info.
Old 26-02-2007, 09:04 PM   #12 (permalink)
The High 5 Flyer
sam9s's Avatar
This mojopac thing looks interesting, In this case I presume when you use the external HDD as an independent PC you are in constant communication with it. Well in that case Firewire would come in handy as then the speed would not be a bottleneck to access applications.
Good thing, neat and new info for me I am gonna try this one with my 30 GB video iPod....thanks Reps for you
sam9s is offline
Old 26-02-2007, 10:23 PM   #13 (permalink)
Yes one can carry their desktop pc in a usb drive/mobile phone/ ipod/and many other things to come where size will increase & so will the interface speed.
Last few days using mojopac has changed my way of working, now atleast I dont waste time copying data to & fro from my main pc. You should try it & post ur comments in that review I posted.
Old 26-02-2007, 11:49 PM   #14 (permalink)
aryayush's Avatar
I am slightly confused here. How can a casing make your existing hard drive's transfer rate faster? Is that possible?
Sorry if that sounds like a stupid question!
aryayush is offline
Old 26-02-2007, 11:59 PM   #15 (permalink)
The High 5 Flyer
sam9s's Avatar
I will definately, right now I am in bangalore, will try with my iPod once I am back in Delhi, would probably need your help then....
sam9s is offline
Old 27-02-2007, 12:46 AM   #16 (permalink)
No its not realy a stupid question.
The casing provides an interface usb /firewire, now in both the case I am going to use same 7200 rpm hdd, but the interface will use different archeciture as explained by sam9s in ealier post.
So using firewire interface will speed up the transfer rate.
__________
I am eagerly awaiting ur return to delhi I would be more than happy to be of any help, though using mojopac is quite simple.
Old 27-02-2007, 01:23 AM   #17 (permalink)
 Macboy
goobimama's Avatar
An internal HDD over a SATA/PATA interface will be anyday faster than either of the formats (FW or USB), but its the external factor that we're talking about. Unless one has got an eSATA port along with a SATA harddrive, FireWire is the way to go...
