Old 26-02-2007, 12:45 PM   #1 (permalink)
soumya's Avatar
Question Display going blank after the xp loading screen
i have geforce fx 5200 and the display is going blank after the xp loading screen. safe mode is also not working!
I blog at http://windowsxperience.wordpress.com/
soumya is offline
Old 26-02-2007, 01:10 PM   #2 (permalink)
Arsenal_Gunners's Avatar
Default Re: Display going blank after the xp loading screen
Try to repair the os with xp cd.
Arsenal_Gunners is offline
Old 26-02-2007, 01:18 PM   #3 (permalink)
thunderbird.117
Posts: n/a
maybe your graphics card has gone count?.
Old 26-02-2007, 01:24 PM   #4 (permalink)
SO why the loading screen is there.
Old 26-02-2007, 01:31 PM   #5 (permalink)
shashank4u's Avatar
check without graphics card..
Be like a postage stamp-stick to one thing until you get there.
shashank4u is offline
Old 26-02-2007, 04:24 PM   #6 (permalink)
TechTin.com
ravi_9793's Avatar
Do the following steps..........
check the jumper setting of the card
do you not hear beeps? they give you a rough idea of what the problem is
__________
Other things U need to check is compatibility of MO with ur graphics card....colling system of the cabinet.
ravi_9793 is offline
