Old 25-02-2007, 11:36 PM   #1 (permalink)
ayush_chh's Avatar
Default problem with core2duo
three of my friends bought a core2duo and 512MB DDR2 recently.....there's a problem. whenever they play music and copy something together, system cannot play song well...IS this the problem with core2duo OR some settings must be changed ? please help...
eXPerience is what a MAN learn's fROM.....
ayush_chh is offline
Old 25-02-2007, 11:39 PM   #2 (permalink)
dOm1naTOr's Avatar
Default Re: problem with core2duo
Are they usin Vista beta?
G3: XPS M1530 |
FZ 16.
dOm1naTOr is offline
Old 25-02-2007, 11:50 PM   #3 (permalink)
ayush_chh's Avatar
no not at all. they r usin XP pro
Old 25-02-2007, 11:54 PM   #4 (permalink)
dOm1naTOr's Avatar
It maybe some sound driver issue or something else, but defenitely not of proccy.
*Such issues are not due to proccys
*C2D is one of the best multithreading CPU around nd is never prone to this type of complaints.
*Might be issue of music player, try different player.
*Update mobo nd sound drivers from net
G3: XPS M1530 |
FZ 16.
Old 25-02-2007, 11:59 PM   #5 (permalink)
TechTin.com
ravi_9793's Avatar
make sure they have updated sound driver,and prefer to play songs in WMP.
There may be many cause behind it......does ur sound card support ur speaker..and many more.
ravi_9793 is offline
Old 26-02-2007, 01:44 AM   #6 (permalink)
Rebooting
Choto Cheeta's Avatar
I think you should 1st see whether the DMA is enable or not... 2nd start up the Task Manager and see if there is any unusual process taking high resources... if yes trace that, and if a virus/spyware/any such clean it...
Post back,...
rebooting
ChotoCheeta.com
Choto Cheeta is offline
Old 26-02-2007, 07:13 AM   #7 (permalink)
You gave been GXified
gxsaurav's Avatar
DMA is on in WinXP by default. update the sound driver & don't play wma in latest version of winamp. It has high CPU usage problem
about.me/gxsaurav
gxsaurav is offline
Old 26-02-2007, 09:18 AM   #8 (permalink)
TechTin.com
ravi_9793's Avatar
I think I have got ur solution.
Yes...@saurav_cheeta is right...........there may be some process who are eating the system resuorce.
Do one thing,and post the result here.In the icon tray (botton right)....exit the intel sound maneger (sound effect).I think it will solve ur problem.
Do let me know the result.....
Old 26-02-2007, 12:17 PM   #9 (permalink)
Rebooting
yup... but whats the gurrenty that user wont have messed up... lol...
rebooting
ChotoCheeta.com
Old 26-02-2007, 02:43 PM   #10 (permalink)
deathvirus_me's Avatar
Question Re: problem with core2duo
Let me guess .. copying something from the cd/dvd drive ?? .. which mobo ?? Could be missing jmicron drivers
deathvirus_me is offline
Old 27-02-2007, 05:27 AM   #11 (permalink)
caleb's Avatar
This is an interesting post...I'm eager to see the solution to this problem.
caleb is offline
Old 15-03-2007, 01:27 PM   #12 (permalink)
ayush_chh's Avatar
@deathvirus_me
all of them use SAMSUNG DVD writer or combo drive
__________
this does not happen with 1 GB RAM
__________
mobo is some intel 945 chipset...
Old 15-03-2007, 04:23 PM   #13 (permalink)
darklord's Avatar
Care to mention the mobo ?
darklord is offline
Old 16-03-2007, 08:04 PM   #14 (permalink)
ayush_chh's Avatar
Gigabyte 945gz
Old 16-03-2007, 08:48 PM   #15 (permalink)
gxsaurav's Avatar
Like I said above, first upgrade the sound card drivers. Install latest directX & check which songs they are? could be a decoder problem
about.me/gxsaurav
gxsaurav is offline
