Old 25-02-2007, 09:48 PM   #1 (permalink)
Default speaker selection
hi
can neone suggest me good speakers for a range of 3-5k(2.1 or 5.1)
purujitb is offline
Old 25-02-2007, 09:52 PM   #2 (permalink)
gooby pls
Third Eye's Avatar
Default Re: speaker selection
You can buy Creative Inspire 5200 5.1,the speaker is old but gives great performance.
Third Eye is online now
Old 25-02-2007, 10:05 PM   #3 (permalink)
TechTin.com
ravi_9793's Avatar
yes..creative inspire 5.1
ravi_9793 is offline
Old 25-02-2007, 10:19 PM   #4 (permalink)
do consider logitech x-230 (2.5k) 2.1
and logitech x-530 (5.5k) 5.1
Faun is offline
Old 25-02-2007, 10:32 PM   #5 (permalink)
Host4Cheap.org
Sukhdeep Singh's Avatar
Altec Lancing ATP3
http://www.host4cheap.org/
Sukhdeep Singh is offline
Old 25-02-2007, 10:52 PM   #6 (permalink)
shantanu's Avatar
Creative 5.1 inspire inspires me a lot
shantanu is offline
Old 25-02-2007, 10:57 PM   #7 (permalink)
The Transcendental
Creative SBS 5.1 70W RMS is good enough for its price (not the best) bought mine for Rs. 3k a couple of months back
:::::::::: When freedom is outlawed, only outlaws will have freedom ::::::::::
..:: Free Radical ::.. is offline
Old 25-02-2007, 11:01 PM   #8 (permalink)
dOm1naTOr's Avatar
get X530 for 5~5.5k. Its the best in the class.
G3: XPS M1530 |
FZ 16.
dOm1naTOr is offline
Old 25-02-2007, 11:32 PM   #9 (permalink)
thanks guys i appreciate it
purujitb is offline
Old 26-02-2007, 03:33 PM   #10 (permalink)
piyush gupta's Avatar
It depends on your requirement
if u like soft calm and romentic music go for Altec Lansing
If u like DJ type music go for Creative od Intex or something like that
piyush gupta is offline
