Old 25-02-2007, 11:37 AM   #1 (permalink)
shashanktyagi1's Avatar
Default Unpredictable Problem
I have a HP desktop with Pentium D. I also Upgraded it with a Graphics card of ASUS GeForce 6200. It was working fine until i installed a new harddrive SATA 250GB. After that it began to show sudddenly that monitor was sleeping and computer used to hang. It happens when any graphic intensive work is done. and after leaving it for some time it again works for few hours. i tried to check it by keeping the cabinet open but to no avail. got the graphics card checked but no problems there. after the problem starts the monitor sleeps in just five minutes if i restart again. computer is working fine if i take out the card and use the internal card with my motherboard. is the problem overheating or is it in the PCI slot.
shashanktyagi1 is offline
Old 25-02-2007, 01:09 PM   #2 (permalink)
Default Re: Unpredictable Problem
The trouble is with PCI slot mostly.
it happened to me once.
long time back
Techno Monkey is offline
Old 25-02-2007, 02:01 PM   #3 (permalink)
a_g = JPKN
s18000rpm's Avatar
most probably its PSU problem, the HP PSU is not sufficient enough for powering a Gfx. Card & the 250GB HDD
HP comes with a PSU whose output is enough JUST for m/b & only one HDD.
i own HP Pavilion Desktop a1210in, its PSU's max. output is 250Watts.
check your PC's PSU, & try with a bit more powerful PSU.
& this HP cabinets is very small & has only one Fan (rear). so heat can be a problem too.
__________
use this utility to monitor the H/W temp. in your PC Speed Fan HomePage
Direct Download-> Speed Fan v4.31
ASUS K53SV SX520D + BF3
s18000rpm is online now
Old 25-02-2007, 02:10 PM   #4 (permalink)
The Unknown's Avatar
Change your SMPS or PSU. Same Problem with my computer when i had the following load with a 200W AT PSU/SMPS:
p3 500mhz
10gb+40gb
sony cdrw
hp cdrw
other motherboard loads(modem, sound, graphics, etc.)
After Changing the SMPS/PSU, my comp. became very fast!!!
The Unknown is offline
Old 26-02-2007, 08:46 AM   #5 (permalink)
any idead how much will it cost me? to buy a new psu. and of what level should i buy. cause i may also be upgrading my graphics card in near future.
__________
and also why is it that it works fine for some time but when the problem starts then it re occurs without much even if i restart my compu.
Last edited by shashanktyagi1; 26-02-2007 at 08:46 AM. Reason: Automerged Doublepost
Old 26-02-2007, 09:13 AM   #6 (permalink)
TechTin.com
ravi_9793's Avatar
^^^...dont buy PSU below 500-600w.
ravi_9793 is offline
Old 26-02-2007, 09:16 AM   #7 (permalink)
and what about the cost. any idea?
Old 26-02-2007, 11:31 AM   #8 (permalink)
Hells_Fury's Avatar
Browse through this forum. There are numerous threads on power supplies and their costs...
Q6600 G0 (TR Ultra-120), ASUS P5N32-E SLI, eVGA 8800GTX Superclocked (TR HR-03 Plus), Samsung 940BW, Corsair Dominator PC2-8500, CM Stacker 830, 700GB Storage, Corsair HX620W, APC Smart 750VA
Hells_Fury is offline
Old 26-02-2007, 11:36 AM   #9 (permalink)
a_g = JPKN
s18000rpm's Avatar
@shashanktyagi1 did you monitor the Temps.???
SMPS
Zebronics- 400 watts 24 PIN ( 915) = Rs.475/-
Zebronics - 360W Pure- Platinum Srs = Rs.1600/-
(prices @ Chennai)
you can go for either these or other brands like PowerSafe, VIP & if you got mo' money go for Antec, Corsair...
NOTE- Zebronics PSU's Fan makes lots of noise.
Old 26-02-2007, 03:12 PM   #10 (permalink)
450W Rs.1850
Old 26-02-2007, 04:01 PM   #11 (permalink)
TechTin.com
ravi_9793's Avatar
Originally Posted by The Unknown
450W Rs.1850
U have got wrong price.Even cabinet with SMPS (450 W)..wont cost so much.
Old 26-02-2007, 04:39 PM   #12 (permalink)
well right now i have smps of 300 W. the one of 450W of intex is for 600. there are no big brands here in varanasi. i cant wait till i get back to lucknow. before i buy i just want to make sure that prob is not with my PCI slot. any way to do that? and how is intex? i plan to buy it today by 6 pm so please reply soon.
__________
teamperature is 34-35 C. teamp1, teamp 2:54C
in speedfan.
__________
temp after half hour use are 36, 70
Computer games have ruined my life!
I get 'Fire in the Hole' in my dreams
Help ME
Last edited by shashanktyagi1; 26-02-2007 at 04:39 PM. Reason: Automerged Doublepost
Old 26-02-2007, 05:27 PM   #13 (permalink)
__________
in speedfan.
__________
never buy intex. they are chinese!!!!
__________
my engineer gave me for the same price. it is not loacl
Old 26-02-2007, 05:44 PM   #14 (permalink)
then what to buy. there is nothing else available. anyone from varanasi. tell some shop.
Help ME
Old 26-02-2007, 05:52 PM   #15 (permalink)
a_g = JPKN
s18000rpm's Avatar
first experiment with any of your friend's PSU, to make sure the PSU is problem, coz still you havent mentioned the "TEMPARATURE" part.
you maybe facing a temp. related issue too
also try this online "POWER CONSUMPTION CALCULATOR"
Old 26-02-2007, 05:52 PM   #16 (permalink)
assasin's Avatar
See if u can find iBall or Frontech.they r a tad better than Intex.i had a very bad xperience with Intex,had to send it for servicing 3 times in 2 months.My present iBall is performing OK.
assasin is offline
Old 26-02-2007, 11:45 PM   #17 (permalink)
TechTin.com
ravi_9793's Avatar
Than most probably ur engineer has cheated you.Can you post the company name of the SMPS.
Old 27-02-2007, 12:51 PM   #18 (permalink)
my frnds also have of same wattage. had the prob again so removed graphics card. now working fine. also my computer has become little slow after the second harddisk. temperature i swell below 40 always. mean 36-37, 67-68.
the online calci showing 380 watt needed. now will be buying from lucknow so please give exact price of any 500+ watt smpc. budget around 2000
Help ME
Old 27-02-2007, 01:03 PM   #19 (permalink)
a_g = JPKN
s18000rpm's Avatar
ask Gx_Saurav for Lucknow shops & prices
for the slow system, check the HDD cables, coz you might have loosened them while removing Gfx. card & if possible remove one of the HDD.
Old 27-02-2007, 02:50 PM   #20 (permalink)
i dnt remember. i thnk it starts with 'V'
Old 27-02-2007, 04:20 PM   #21 (permalink)
shantanu's Avatar
you can go for cooler master OR ZEBRONICS..
Zeb-500 is 1950/-
and clooremaster 500- is 2350/-
shantanu is offline
Old 27-02-2007, 06:33 PM   #22 (permalink)
Shasanka_Gogoi's Avatar
Go for the Antech models, may be u would have to stretch ur budget to get these PSU's but they are worth it. Even try upgrading ur graphics card drivers. Thanks......
Shasanka_Gogoi is offline
Old 28-02-2007, 03:45 AM   #23 (permalink)
graphic card drivers are updated. also tell any way to check my pci slot.
Help ME
