Old 23-02-2007, 07:07 PM   #1 (permalink)
pushkaraj's Avatar
Default HDD not detected sometimes
I have connected 3 sata hdd(80 + 40 + 40) to my amd athlon 3200+ with 512 mb ram.The smps is 350W. I also have a LG dvd writer and a cmi8738 sound card. My xp is installed on one of the partitions of the 80 gb hd. Sometimes one of the remaining two hd is not detected in the POST and then it also doesn't show up in xp. Could this be mean the 350W smps is falling insufficient?
The statistics on sanity are that 1 out of every 4 humans is suffering from some form of mental illness:shock:
Think of your 3 best friends. If they are OK, then it's YOU:grin::grin::grin:
pushkaraj is offline
Old 23-02-2007, 07:36 PM   #2 (permalink)
Security Exp
47shailesh's Avatar
Default Re: HDD not detected sometimes
Please discribe your HDD conection with busses and jumper settings on HDD
We Love Once, And When We do We do it Well
47shailesh is offline
Old 23-02-2007, 07:52 PM   #3 (permalink)
shantanu's Avatar
I think your POWER supply is too less for AMD
see your MOBO manual i think they might have written that atleast a 400 watt SMPS recommended and you are using three HDD so go in for 450 watt atleast...
shantanu is offline
Old 23-02-2007, 08:04 PM   #4 (permalink)
GUNNING DOWN TEAMS
wizrulz's Avatar
true u need atleast 400W..power supply for AMD...correct me if i am wrong
wizrulz is offline
Old 23-02-2007, 08:07 PM   #5 (permalink)
shantanu's Avatar
No you are absolutely RIGHT
shantanu is offline
