i recently bought a AMD AM2 Athlon 3000+.
i need to know some things...
1.How do i check for the cache memory
2.And AM2 is a answer to Intel's dual core right?
Pleae let me know.
And i have a 512 DDR2 @ 533Mhgz.
and a Geforce 6200 @ 256MB.
Now can i play far cry,F.E.A.R and stuff like that.
Thank you.
and this is my first post ever in any domain.
i need to know some things... 1.How do i check for the cache memory
Pleae let me know.
Thank you.
1. Use CPUZ to find out. Google for it.
2. Yes AM2 is answer to Inter Core 2 Duo and yes it is a dual core.
Yes you can play the game with low or medium settings.
socket AM2 supports DUAL CORE but the CPU youa re using is a single core CPU... and NOT a DUAL CORE.. DUAL core series is X2 and FX from AMD and C2D is well above Athlon 3000+ and even it beats X2 series
