Old 23-02-2007, 01:53 PM   #1 (permalink)
madmax_tt's Avatar
Default Need For Speed Problem
i have nVIDIA GeForce FX 5200 128MB AGP. Since i cannot use it in my board, i let my frens to use it. his board in Mercury 865 series(dont know the exact). Need For Speed: UNDERGROUND 2 was running fine wit his onbaord graphic( at 640X480), but cannot run with the graphic card. i gives an error saying that it has encountered a problem and need to close. Splinter Cell: Chaos Theory, Prince Of Persia: The 2 Thrones, SWAT, FEAR etc...etc...etc... were also running perfectly. I format C:\ and even reinstall windows with latest graphic card driver but wont run. Processor is P4 @ 2.8Ghz, RAM is 2X 256MB. plz help
madmax_tt is offline
Old 23-02-2007, 02:03 PM   #2 (permalink)
shashank4u's Avatar
Default Re: Need For Speed Problem
check for the patches if available for nvidia card ..
then check ..and also read the file read me..comes with the game..
Be like a postage stamp-stick to one thing until you get there.
shashank4u is offline
Old 23-02-2007, 10:14 PM   #3 (permalink)
Fighter's Avatar
maybe its high time you upgrade the drivers for your graphics card. and also check for any bottlenecks in the system using SiSoft Sandra.
Fighter is offline
Old 23-02-2007, 10:21 PM   #4 (permalink)
santu_29's Avatar
whats the driver version of the card.. dont use the latest one..
Unless you have a dream, you are not going to achieve anything in life.
Shoot for the moon, even if you miss, youll fall in the stars.
******************ÏMPÕ§§ÏßL£ ϧ ÑÕTHÏÑG ******************
santu_29 is offline
