Old 23-02-2007, 06:43 AM   #1 (permalink)
tinku dhar's Avatar
Default Virtual memory LOW :( (help)
well ... ,
can anyone tell me y my Virtual memory LOW i have 20 + 80 GB HDD
and now i want to increase Virtual Memory Space plz tell me How much will be PErfect
My now INitial Size is = 400 MB
and MAX is 725 MB
Regards
tinku dhar is offline
Old 23-02-2007, 07:25 AM   #2 (permalink)
An Esoteric Geek
sridatta's Avatar
Default Re: Virtual memory LOW :( (help)
generally.. 1.5 times the size of your RAM is sufficient... If you are facing problems with VM, then there is no harm to increase it. Since, you say that u have two HDD, I would suggest you to allocate the virtual memory in the hard-disk on which windows is NOT installed which will slightly boost your systems' performance...
Any more queries?
sridatta is offline
Old 23-02-2007, 08:05 AM   #3 (permalink)
dOm1naTOr's Avatar
While setting size set the initial ns max at same value. In that case windows is relieved from the task of expanding the size from initial to max during load times.
Also first full defrag ur partition in which u gonna set the VM.
G3: XPS M1530 |
FZ 16.
dOm1naTOr is offline
Old 23-02-2007, 03:08 PM   #4 (permalink)
piyush gupta's Avatar
there is no harm in increasing ur VM
u can increase also tell me whats ur RAM size
piyush gupta is offline
Old 23-02-2007, 09:23 PM   #5 (permalink)
tinku dhar's Avatar
Well my Ram is 256 MB SDRAM
Old 23-02-2007, 09:28 PM   #6 (permalink)
Tech Geek's Avatar
empty up ur drive where ever your OS is installed
Tech Geek is offline
Old 23-02-2007, 09:30 PM   #7 (permalink)
tinku dhar's Avatar
Any more queries?
Plz give the detail of to do it
Old 23-02-2007, 09:32 PM   #8 (permalink)
Tech Geek's Avatar
Buy another 256MB stick
Old 23-02-2007, 09:33 PM   #9 (permalink)
tinku dhar's Avatar
Wat u mean by tht ?
__________
Well ... ,
i think this 256 MB is good tooo i will buy but now its not possible to Soo gemme some trick i got it be4 but dunno the link forgot
Old 24-02-2007, 02:18 AM   #10 (permalink)
An Esoteric Geek
sridatta's Avatar
Right click on my computer, go to properties --> Advanced --> Settings under performance -> Advanced
Click change beside virtual memory
select the drive of harddisk on which ur windows is not installed and enter custom size as 384 mb to 500 mb suppose... You can also allocate more.. change the 384 to more..
click on SET
Now, deallocate the virtual memory buy choosing "no paging file" option for your drive on which ur windows is installed..(i.e. removing previous allocation) and save changes..
sridatta is offline
Old 24-02-2007, 02:34 AM   #11 (permalink)
shantanu's Avatar
IF you have 256 MB then set your Virtual memory to 512 512 in both initial and max.
shantanu is offline
Old 24-02-2007, 02:46 AM   #12 (permalink)
a_g = JPKN
s18000rpm's Avatar
a point to NOTE tinku
allocate the VM in non OS HDD, to gain better performance.
__________
this pic might be helpful
select "No Paging File" for C: Drive & allocate some space for Page File in other non OS Drive.
select the CustomSize (marked with blue circle), & set the desired size. (always keep both minimum & maximum as same)
ASUS K53SV SX520D + BF3
s18000rpm is online now
Old 24-02-2007, 02:48 AM   #13 (permalink)
shantanu's Avatar
@s18000RPM are you saying that we should have the PF in another drive then root drive...
shantanu is offline
Old 24-02-2007, 02:54 AM   #14 (permalink)
a_g = JPKN
s18000rpm's Avatar
yes. its reccomended in Microsoft's Support Page itself
To enhance performance, it is good practice to put the paging file on a different partition and on a different physical hard disk drive.
That way, Windows can handle multiple I/O requests more quickly. When the paging file is on the boot partition, Windows must perform disk reading and writing requests on both the system folder and the paging file. When the paging file is moved to a different partition, there is less competition between reading and writing requests.
read the whole quote, very imp. stuff. for those having two+ HDD
source: Microsoft Support - Article 314482
Old 24-02-2007, 02:58 AM   #15 (permalink)
shantanu's Avatar
I thought you were saying that multiple PF for each drive my mistake
shantanu is offline
Old 24-02-2007, 09:31 AM   #16 (permalink)
deathvirus_me's Avatar
Infact PF extended over multiple drives is recommended too ..
deathvirus_me is offline
Old 24-02-2007, 05:07 PM   #17 (permalink)
tinku dhar's Avatar
__________
Dude i gave Reputation hehe
well now tell me wat suld be the MB in INTIAL and MAX ?
i mean how much suld be Good ?
Old 24-02-2007, 05:40 PM   #18 (permalink)
a_g = JPKN
s18000rpm's Avatar
500 is enough, but if you have PhotoShop, then make it 1GB
Old 24-02-2007, 05:48 PM   #19 (permalink)
GUNNING DOWN TEAMS
wizrulz's Avatar
The recommended minimum size is equivalent to 1.5 times the RAM on your computer, and 3 times that figure for the maximum size.For best performance, do not set the initial size to less than the minimum recommended size under 'Total paging file size for all drives'
Just a suggestion...
wizrulz is offline
Old 24-02-2007, 05:55 PM   #20 (permalink)
tinku dhar's Avatar
I will keep 800 MB both for initial as well as MAX is it ok ?
i have 40 Gb of space in one Drive and my ram is 256 MB
Old 24-02-2007, 05:58 PM   #21 (permalink)
a_g = JPKN
s18000rpm's Avatar
no problem.
Old 24-02-2007, 06:01 PM   #22 (permalink)
caleb's Avatar
^^That'll do tinku, that'll do.
caleb is offline
Old 24-02-2007, 06:03 PM   #23 (permalink)
shantanu's Avatar
No @ wizrulz its not recommended.. in Xp blue screen error become frequent by that..
shantanu is offline
Old 24-02-2007, 06:04 PM   #24 (permalink)
GUNNING DOWN TEAMS
wizrulz's Avatar
by what can u explain????
wizrulz is offline
Old 24-02-2007, 06:09 PM   #25 (permalink)
shantanu's Avatar
ok ... When multiple PF is placed in different partitions .. windows xp uses it for the programs stored in that drive only.. and copies that data back to the main system PF whether stored in C or after that in any drive like : if PF is not in C then it will check D..
SO now if a program in F drive runs it will be copied to the master PF and then will run.. so the thing is when you run a game or heavy app. then two pf's will be used and DATA transfer rates will vary among partitions... so they will reproduce a blue screen error or that error which says.........
The memory could not be read or write...
that STOP x0xxxxx one..... read HELP and SUPPORT OF WINDOWS XP also you will see it there also....
shantanu is offline
Old 24-02-2007, 06:10 PM   #26 (permalink)
GUNNING DOWN TEAMS
wizrulz's Avatar
aree baba when i said to have multiple PF is placed in different partitions ???
this is from microsoft site
Notes• To have Windows select the best paging file size, click System managed size. The recommended minimum size is equivalent to 1.5 times the RAM on your computer, and 3 times that figure for the maximum size. For example, if you have 256 MB of RAM, the minimum size is 384 MB, and the maximum size is 1152 MB.
• For best performance, do not set the initial size to less than the minimum recommended size under Total paging file size for all drives. The recommended size is equivalent to 1.5 times the RAM on your computer. It is good practice to leave the paging file at its recommended size. However, you may increase its size if you frequently use programs that use much memory.
• To delete a paging file, set both the initial size and the maximum size to zero, or click No paging file. We strongly recommend that you do not disable or delete the paging file.
wizrulz is offline
Old 25-02-2007, 03:51 AM   #27 (permalink)
tinku dhar's Avatar
hehehehehehehe ok ok wateva let me try and see
will let u guys know
Thnx
__________
ok thnx Guys its workin gr8 now
thnx very much
PEACE
