Old 22-02-2007, 08:06 PM   #1 (permalink)
Default help need in upgrading...
i have AMD Athlon™ 64 3200+
1gb DDR ram
XFXgeforce 6600 256 MB (pci )
MSI RS482 mother board ....
right now i am able to play all the new games (eldar scrolls 4,ghost recon advanced warfighter..etc) at1024*738 resolution with 2X antilising,antritropic filltering on...BUt when i change the the resolution to 1280*1024..
i am thinking of upgrading...RAm to 2gb(should i add more????),,
also plz suggest the highest(i mean most advanced) grafhic card ..compatible with my motherboard...
p.s. are the new geforce 8800GTX or geforce 8800gts compatible with my motherboard ?????
duron111 is offline
Old 22-02-2007, 08:09 PM   #2 (permalink)
Tech Geek's Avatar
Default Re: help need in upgrading...
I don't know abt Graphic card.
about the ram- Buy another 1GB ram.
Tech Geek is offline
Old 23-02-2007, 02:02 AM   #3 (permalink)
caleb's Avatar
1gb DDR ram
You don't need 2GB instead buy 1GB more and save the money to buy a good graphics card...in April the budget DX10 compatible cards will be out.
Yes 8800GTX & 8800gts are compatible with your mobo
caleb is offline
Old 23-02-2007, 08:51 AM   #4 (permalink)
dOm1naTOr's Avatar
Yes for ur current proccy nd gcards 1 Gb is enough nd for games its ur card which is bottleneck nd not memory or CPU.
Also u can't even get half the real perfomance of 8800GTX in ur system. Ur CPU nd RAM will be a big bottleneck. Ull need about 2GB dual channel nd a min of X2 3800+ to even stress a 8800GTX a lil bit.
G3: XPS M1530 |
FZ 16.
dOm1naTOr is offline
Old 23-02-2007, 09:10 PM   #5 (permalink)
so ur telling i should change the processor ?...
the max i can put with the 939 pin is x2 4200 i guess but whts its cost?
also should i wait before i get a new G-card ?
duron111 is offline
Old 23-02-2007, 09:12 PM   #6 (permalink)
Tech Geek's Avatar
price is Rs8500
