Old 22-02-2007, 03:56 PM   #1 (permalink)
blademast3r's Avatar
Default Making portable hard drive
Hi guys i head read somewhere a tutorial where one could make a portable hdd with a 2.5 hard drive and some portable drive casing..
so now i hav a 3.5 inch 20gb hdd which i want to convert into a portable hdd...cud sm1 pls guide me...what casing/convertors will i need and how much will they cost...
blademast3r is offline
Old 22-02-2007, 04:09 PM   #2 (permalink)
nil_3's Avatar
Default Re: Making portable hard drive
The casing for Laptop hard discs(80/120GB) are available in market. The price for the casing marketed by Transcend is Rs. 850/-(in Kolkata). Low priced(Rs. 200/-) casings are also available. Installation is hassle-free. If you purchase portable Hard Disc and casing from the same shop, they will assemble them.
P4 3.0GHz Dual-core.
Intel 945GNT MoBo.
1GB RAM.
Seagate 160GB SATA HDD.
HP 16X Dual Layer DVD Writer.
Coloursit 450Watt SMPS with NAVTECH cabinet.
Samsung SyncMaster 740N TFT LCD 17" monitor.
nil_3 is offline
Old 22-02-2007, 04:28 PM   #3 (permalink)
but i hav a pc hd not laptop...dyu get casings for them too...
Old 22-02-2007, 11:26 PM   #4 (permalink)
Pragadheesh's Avatar
Post Re: Making portable hard drive
ofcourse... just approach a computer shop n ask them to do a USB casing over yo 20gb hd.. jus a 15mins work but it would cost u around 700...
my opinion ,dont ever go for portable hard disks(iff size doesnt matter as u would ave power cables n stuufs), rather buy an internal hd n do an external casing for it.. Njoy wid yo portable hd..
Pragadheesh is offline
Old 23-02-2007, 12:29 AM   #5 (permalink)
thats kinda k, cos i cant use this hd in any other way and am in need of portable space, where wud i get a 20bg portable hd for rs 700!!
thanks
Old 23-02-2007, 12:43 AM   #6 (permalink)
u can get a converter to convert ur IDE as well as SATA hard disk in to Usb interface just for 1000bugs in mumbai
:P If U lIkE mY SUggeStIon Plz ADd SOmeThing tO mY RePUtaIon :)
buntythecool is offline
Old 23-02-2007, 02:16 AM   #7 (permalink)
caleb's Avatar
Go for a brand called GEMINI (it's cheap and reliable brand) you will get the USB case with all the required cables & a manual with pictures on how to assemble it...it is as easy as adding light bulb.
There are 2 models in GEMINI
1. Rs.500/-= without cooling fan
2. Rs.850/-= with cooling fan
The cooling fan is not really required...I say this coz I hav both of them which I purchased a few months ago and both work well. The advantge of the HDD case with cooling fan is that you can alternatively connect your internal CD/DVD Writer to that case to make it a external CD/DVD Writer.
caleb is offline
Old 23-02-2007, 08:32 AM   #8 (permalink)
Šupər♂ - 超人
koolbluez's Avatar
Here u go.... full details... illustrated.
Note Book Review - DIY Portable Hard Drive
Recycle a laptop hard drive
The latter page's link jumps page every 3 sec or so... so... copy contents asap into some word document
koolbluez is offline
Old 24-02-2007, 06:03 PM   #9 (permalink)
thank u sooo much caleb and koolbluea
