Old 22-02-2007, 09:14 AM   #1 (permalink)
Default LCD Monitor lines.....
I have a LG LCD Monitor...model no is LG L1730s....
recently it used to show a line vertically across my monitor which is of 1 pixel thickness. The color of the line used to vary depending on the application used...After 2 weeks or so the line gradually disappeared. It used to be displayed only when I used the system for more than one hour or so. Once it appears restarting the machine will also not solve the problem.
Is it a monitor complaint or some mistake related to OS that I have installed?
My OS is Windows XP with Sp2 and I also have a graphics card. Please help if any of you have experienced such problems.
Thanks in advance.
vivektheone is offline
Old 22-02-2007, 09:28 AM   #2 (permalink)
Default Re: LCD Monitor lines.....
This is a sign of some problem with LCD, my friend laptop started having such problem & then one fine day that thin line got 2 inch thicker band & it finally had to be replaced.
If ur lcd is under warranty then get it checked/replaced.
ranjan2001 is offline
Old 22-02-2007, 12:30 PM   #3 (permalink)
Tech Geek's Avatar
it is the problem with the monitor.
get it checked
Tech Geek is offline
Old 23-02-2007, 01:50 PM   #4 (permalink)
Default Thanks...
Thanks friends...It is in the warranty period. I think I will better try replacing it or something...And rep's for u as well..
Old 23-02-2007, 02:55 PM   #5 (permalink)
Phenom II X4 920 Owner
prateek_san's Avatar
its monitor problem ....get it checked
"A strong positive mental attitude will create more miracles than any wonder drug." - Patricia Neal
prateek_san is offline
