Old 22-02-2007, 03:26 AM   #1 (permalink)
Phenom II X4 920 Owner
prateek_san's Avatar
Default Need Help bout Huawei MT841 modem.
can anyone tell help me how to create a wifi network with MT841 , and also which wifi device is required for the modem.....
please tell me in brief.....and also can i get that wifi device at Nehru Place, New delhi....
i need to configure wifi to use my net connection with laptop, so help me guys...
PLEASE GUYS HELP ME TO FIND WHICH WIFI DEVICE WILL WORK WITH THIS MODEM.....I NEED THE DEVICE AS QUICKLY AS POSSIBLE, SO REPLY SOON....
PLEASE HELP
I HAVE SEARCHED A LOT....NO LUCK.
thanks..
"A strong positive mental attitude will create more miracles than any wonder drug." - Patricia Neal
prateek_san is offline
Old 22-02-2007, 08:39 AM   #2 (permalink)
Hells_Fury's Avatar
Default Re: Need Help bout Huawei MT841 modem.
Im not too sure bout this but I think you have to buy an add-on wi-fi card that you have to install in the modem. After that you can configure it using the HTML interface provided.
Q6600 G0 (TR Ultra-120), ASUS P5N32-E SLI, eVGA 8800GTX Superclocked (TR HR-03 Plus), Samsung 940BW, Corsair Dominator PC2-8500, CM Stacker 830, 700GB Storage, Corsair HX620W, APC Smart 750VA
Hells_Fury is offline
Old 22-02-2007, 02:00 PM   #3 (permalink)
wats the wifi device......? and how to configure that...
Old 23-02-2007, 08:23 AM   #4 (permalink)
Hells_Fury's Avatar
I dont know what the device is, maybe you can ask a vendor itself. Once you install the wi-fi card, you can configure it by using the configuration console of your modem. Just type your modems IP address in IE and it will come up in the browser.
Old 23-02-2007, 02:57 PM   #5 (permalink)
ok.....i know bout the config. ,just the device , these guys are not able to tell which device will work.....btw thanks...
Old 24-02-2007, 09:25 AM   #6 (permalink)
Hells_Fury's Avatar
Oh..sorry, cant help you out with which device you need to buy. I thought you needed help on configuration...
