Old 20-02-2007, 09:31 PM   #1 (permalink)
WOW... are you?
gsoul2soul's Avatar
Default USB hide and seek
Sometimes my "Pen Drive" is detected at one go !!!
And then most (I'm atlking MOST of the time...) it won't get recognised.
I have to plug it in / and plug it out!!! couple of times before it's accepted.
Even happened with my "iPod"
help... what to do? (both of the front USB slot are acting like irritating "Slut"s)
help... gsoul here
gsoul2soul is offline
Old 20-02-2007, 09:53 PM   #2 (permalink)
Still Shining!
Lucky_star's Avatar
Default Re: USB hide and seek
The problem is with your slots not with the ipod or PD.
Try with the ports in the back. Buy a USB extension cable to use the back ports easily.
Nokia N86 8MP
Lucky_star is offline
Old 20-02-2007, 10:05 PM   #3 (permalink)
Security Exp
47shailesh's Avatar
^^even if above suggestion does'nt solve ur problem then remove drivers of USB drives and re-install them with the latest one available...
We Love Once, And When We do We do it Well
47shailesh is offline
Old 20-02-2007, 10:14 PM   #4 (permalink)
Cool G5's Avatar
Thumbs up Re: USB hide and seek
Also check for dirt or rust in the usb ports of ur pc.
Cool G5 is offline
