Old 20-02-2007, 02:06 PM   #1 (permalink)
assasin's Avatar
Default Need Help in buying lcd monitor
Hi Guys! Need ur help again
I'm gonna buy a lcd monitor in bout 10-12k.My requirements r:
1>Sud hav DVI input.
2>response time sud be bout 4ms - 8ms.
3>Sud hav a wide viewing angle.
4>Sud hav good color reproduction and good brightness 2 contrast ratio.
So plz suggest some good models.
Thnx in advance.
assasin is offline
Old 20-02-2007, 04:58 PM   #2 (permalink)
No pain....No gain
john_the_ultimate's Avatar
Default Re: Need Help in buying lcd monitor
For 13.5k (including tax) you'll can get BENQ 19" widescreen or AOC 19" WS. Else increase your budget to around 15K and get SAMSUNG 940BW (widescreen) or 940B (normal). Another good brand would be VIEWSONIC check their site for different models.
If you want to buy an 17" lcd with DVI then get SyncMaster 740B, it will cost you around 10.5k
john_the_ultimate is offline
Old 20-02-2007, 05:46 PM   #3 (permalink)
wat abt the 17" samsung 740N lcd? it offers a native resolution of 1280x1024 with a refresh rate of 75 Hz and its well suited in your budget
azad is offline
Old 20-02-2007, 06:54 PM   #4 (permalink)
assasin's Avatar
But dude 740N doesnt hav dvi input.It has only D-sub.
assasin is offline
Old 20-02-2007, 07:32 PM   #5 (permalink)
Thnx in advance.
Basically u r looking for jack of all trades LCD & u wont find one in ur budget.
What is ur purpose gaming, movies, graphics etc??? DVI is better for graphic since it gives a digital output.
Many choices are available but truth of the matter is that these ms timings are for grey to grey & not real black to white.....................so dont run after numbers alone, understand what u need that fast ms timing for........do u game?
How wide? Most TN panels will fit into ur budget but their horizontal wide angle is still not what they rate & vertical wide angle (viewing angle) is less than hrizontal.
Color is a subjective choice & most high end graphic purpose LCd produce superior colors but will have low response time starting from 12-16ms.
So moral of this is that u wont get 'all-in-one' LCD, define ur purpose & then make a choice.
Hope this helps.
ranjan2001 is offline
Old 20-02-2007, 08:07 PM   #6 (permalink)
If u can stretch the budget to 14k then can try this one:
BENQ FP92W (widescreen, 16:10, 4 ms).
BenQ is really gaining pace in India. Else u are free to choose what u like.
Faun is offline
Old 20-02-2007, 10:11 PM   #7 (permalink)
assasin's Avatar
@ranjan2001 My main purpose is gaming and movies.Since i hav a 6600 gfx crd so i'm searching 4 dvi input.Thnx 4 ur informative post.
@T159 By how much do i hav to increase my budget.
assasin is offline
Old 20-02-2007, 10:44 PM   #8 (permalink)
The Frozen Nova
casanova's Avatar
Viewsonic 1912wb 19" wide lcd. 13000/-
www.nerdweed.blogspot.com
casanova is offline
Old 20-02-2007, 10:49 PM   #9 (permalink)
Then go for Viewsonic 1912wb 19" wide lcd. 13600/-here in delhi , not sure which city u belong to
It has DVI & dvi -sub excelent color reproduction right out of the box. I tried many & can recomend that model, though I finally bought another one 20inch.
Old 20-02-2007, 11:08 PM   #10 (permalink)
assasin's Avatar
Thats wat i've decided after a lot of googling.Thnx to all of u guys.
assasin is offline
Old 20-02-2007, 11:46 PM   #11 (permalink)
u r welcome!
Old 21-02-2007, 10:13 AM   #12 (permalink)
da' Ťurntable ruleth
techno_funky's Avatar
Just wanted to put in that the Viewsonic does not support HDMI while the samsung 940bw has DVI+HDMI.
| Dell Studio 15 | iPod Touch 16GB (Stolen) | iPod Video 5.5G 30GB | Sony Ericsson W910i |
| Sennheiser PX 100 | Sennheiser HD 202 |Creative EP630 | Altec Lansing ATP 3 |
techno_funky is offline
Old 21-02-2007, 10:20 AM   #13 (permalink)
Thats why I earlier said you wont find ALL-IN-1 LCD, though I remember that viewsonic launched another new version of the same having that feature , but not sure if its available here in India.
940BW is a TN panel & viewing angle vertically is quite less than the horizontal & the menu is too confusing to set.
Old 21-02-2007, 12:09 PM   #14 (permalink)
assasin's Avatar
^^^ Since LG & Samsung service centers r near my house soi've decided to buy a Sumsung LCD Monitor.The 2 models that i've short listed r
940BW and 931BW.
Now i cant decide which one i sud buy.
assasin is offline
Old 21-02-2007, 12:20 PM   #15 (permalink)
Rubbish . It has DVI and D-Sub(VGA). The DVI port supports HDCP. Not that HDCP matters anyway.
C2D E8400@3.8, P5N32-E SLI, 2GB Cellshock DDR2 1000(4-4-4), 8800 Ultra SLI, 2.7TB storage, CM Stacker 830, TT 1200W, Dell 2005FPW, Lots of Audio HW.
Ch@0s is offline
Old 22-02-2007, 10:29 AM   #16 (permalink)
Oh Hell!! yea sheesh i got confused between hdmi and hdcp ,yeps the viewsonic aint got HDCP while the sammy does.
Although HDCP would matter when playing DRM'd media ,a device that is not HDCP compliant will be feeded the downgraded version of the media.
You can read more about HDCP here
Old 22-02-2007, 10:52 PM   #17 (permalink)
premsharma's Avatar
It has been already discussed in another thread on LCD monitors that HDCP is gimmick. Samsung comes after Viewsonic, performance, features & cost wise. Though all of them [models discussed here] have TN panel and response time almost same [GTG], in addition viewsonic also have inbulit speakers.
VG 1912, VG 1921 & VG1939 all vide creen 19" and Viewsonic is the first one to launch 17" widesreen in India. It is available now.
premsharma is offline
Old 23-02-2007, 12:08 AM   #18 (permalink)
Rising ApocalypsE
keith_j_snyder2's Avatar
Viewsonic,I m not sure about the model no. but probably be this one Viewsonic 1912wb 19".It has 2 MS response time & its a gamer's choice.Sure it has DVI port.Over all if it was there at my time,this one should be my pick.Currently i m having CMV CT-720D.
keith_j_snyder2 is offline
Old 23-02-2007, 01:48 AM   #19 (permalink)
assasin's Avatar
My dealer told me that he wont be able to get a LCD monitor with DVI input.
So bought a LG L1732S TFT LCD Monitor.
Thnx to all u guys for ur help.
assasin is offline
Old 23-02-2007, 02:37 AM   #20 (permalink)
Rising ApocalypsE
Well ur "dealer" is a true L-O-S-E-R.DVI port starts from 17" monitor upto the rest.Well what have u bought is no problem at all but if u can do 1 thing,then go & slap his face & tell him to surrender his dealership & return to his village & do farming again.Thats the best possible futhure for him!!!
Old 23-02-2007, 07:57 AM   #21 (permalink)
dOm1naTOr's Avatar
@assasin
Viewsonic VA1912wb is a good 19" widescreen one. U can read more about it on:
http://www.viewsonic.com/products/de...ries/va1912wb/
But it has no HDMI inputs. But inorder to use such inputs ull have to have an HDDVD or Blue ray player(X360 or PS3 also).
About DVI.
Consider it only if u are a Gamer nd u need digital input from ur card. U can hardly see any differenve b/w Dsub nd DVI if used with entry level cards nd at low-med res.
G3: XPS M1530 |
FZ 16.
dOm1naTOr is offline
Old 04-03-2007, 05:49 PM   #22 (permalink)
assasin's Avatar
Guys i've bought a 17" LG L1752S TFT monitor.Now i wanna know if its picture quality is as good as Samsung 740B,931BW & 940BW.First i got a LG L1732S,it had a few backlight probs so got it replaced with a 1752S.
assasin is offline
Old 04-03-2007, 06:48 PM   #23 (permalink)
The High 5 Flyer
sam9s's Avatar
Thnx in advance.
wow again a big discussion on monitors....we dont get tired of monitor discuessions do we.........assasin consider this thread as well with some real heavy monitor discuession...
Help in buying a LCD monitor.
sam9s is offline
