Old 20-02-2007, 09:34 AM   #1 (permalink)
Default Cabinet Power Switch (Power Button) ?
Hello Friends,
I have ibox cabinet from iball.
From last 1 month I noticed some changes with cabinet power switch, before that, with ONE GENTLY PUSH PC GET ON but now I need to Press and Hold this Power Switch for 3-5 seconds.
I have just 15 days old Power Safe 400W Gold PSU in this Cabinet.
What the problem is? Power Switch going to dead?
Any Help/Suggestion Please?
Thanks.
Stick is offline
Old 20-02-2007, 11:29 AM   #2 (permalink)
Tech Geek's Avatar
Default Re: Cabinet Power Switch (Power Button) ?
is the main plug on all the time or you switch it on just before you start your computer??
Tech Geek is offline
Old 20-02-2007, 11:34 AM   #3 (permalink)
No, not at all, I strictly Put OFF main plug before leaving Chair each and every day.
I switch it on just before start PC.
Stick is offline
Old 20-02-2007, 11:35 AM   #4 (permalink)
Tech Geek's Avatar
OK
then the power will take about 3-5 to reach the ups then the only can the PC get on. this happens to me everyday.
Old 20-02-2007, 01:12 PM   #5 (permalink)
Question Re: Cabinet Power Switch (Power Button) ?
OK
I don't have UPS (it's PSU - smps), and prior to this just with 1 second SMOOTH press & PC get started but now I need to push DEEP and hold switch for 3-5 seconds randomly.
Stick is offline
Old 20-02-2007, 03:18 PM   #6 (permalink)
Tech Geek's Avatar
might be some loose connection inside near the button..
Old 21-02-2007, 01:56 AM   #7 (permalink)
ApoorvKhatreja's Avatar
Hmm...this problem is caused due to dislocation/damage of the spring in the button. Just get it replaced - costs only 20-30 bucks.
http://apoorvkhatreja.blogspot.com
ApoorvKhatreja is offline
Old 21-02-2007, 10:49 AM   #8 (permalink)
Can I replaced it myself? How? Any forum/link where I can get tur with pics
Stick is offline
Old 22-02-2007, 08:19 PM   #9 (permalink)
Bump
Stick is offline
Old 22-02-2007, 08:20 PM   #10 (permalink)
Tech Geek's Avatar
just tell some computer engineer to replace it.
Old 22-02-2007, 08:21 PM   #11 (permalink)
shantanu's Avatar
hi Stick,, why dont to check out the function of power button.. just go to your BIOS and check it sometimes its changed to 3 seconds before power on...
shantanu is offline
Old 23-02-2007, 10:08 AM   #12 (permalink)
I have Win98SE OS
__________
Computer Engineer , arey Jack of all charge Rs.250/- here in Mumbai, think how much Computer Engineer will charge me at least Rs.1000/- and in that price I will manage to get New Cabinet without PSU, and sure will get decent caby.....
Stick is offline
Old 23-02-2007, 10:43 AM   #13 (permalink)
shashank4u's Avatar
3-4 sec shud not bother u...why to spend money if everything else is working fine..
Be like a postage stamp-stick to one thing until you get there.
shashank4u is offline
Old 23-02-2007, 12:16 PM   #14 (permalink)
OK!
If it's not an Problem (prior to this I suspect may be some H/W going to fail and need replace, better to change now before System Fails), I can live with Peace with my System.
Stick is offline
Old 23-02-2007, 04:19 PM   #15 (permalink)
shantanu's Avatar
thats good for you !!!! but the thing is BIOS setting not OS
shantanu is offline
Old 24-02-2007, 12:37 AM   #16 (permalink)
I go through BIOS settings but didn't find the POWER Tab, can you pls tell me where I will find it?
Stick is offline
Old 24-02-2007, 12:41 AM   #17 (permalink)
shantanu's Avatar
you will find it in Power managemant setup or HW monitor..
shantanu is offline
Old 24-02-2007, 09:17 PM   #18 (permalink)
Tech Geek's Avatar
You are right
but that is the only way if you don't know what to do
Old 25-02-2007, 11:57 AM   #19 (permalink)
You are right
Thanks for replies Friends,
yesterday I open Caby and while checking all connectors I found HDD connectors little bit out, use gentle pressure and fix it and than till today have no such problems.
Stick is offline
Old 25-02-2007, 11:59 AM   #20 (permalink)
Tech Geek's Avatar
so is it ok now
Old 04-03-2007, 12:23 AM   #21 (permalink)
so is it ok now
NO
Problem starts again today and now I need to Press Power Switch Too Deep that some time I fear that Cabinet may scroll back?
What's your suggestion now, do I need to replace the spring? Can I do it my self?
Stick is offline
Old 04-03-2007, 12:27 AM   #22 (permalink)
shantanu's Avatar
yeah buddy you can do it yourself
have some confidence and open the cabinet and see what you can make out of it
shantanu is offline
Old 05-03-2007, 09:13 AM   #23 (permalink)
^^Ya I open it and stretch Spring and put it again yesterday, due to Holi I didn't get chance to ON PC but today morning I press Button Gently and PC Start ON without any Problem.
Let's see this time the Problem is gone for ever, by the way what exactly the Spring in Power Button Called, if the problem Strike again than do I need to replace the Whole Unit fitted with Power Button i.e. Some Hardware with White and Black wire which Connected On Mother Board, what it called? and for How much I can buy this?
Thanks for quick reply.
Stick is offline
Old 05-03-2007, 01:07 PM   #24 (permalink)
piyush gupta's Avatar
It cost u around Rs. 20-30 not much
there are only two cables white and black u have to reaplace
i m not sure may be u can get only spring
piyush gupta is offline
Old 05-03-2007, 07:09 PM   #25 (permalink)
Oh!
So I can save lot of money by replacing it my self but can you please name the H/W.
I think cable is not the problem but the Switch (ON/OFF Switch) fit into Power button is creating problem , one side of this Switch end with white and Black cable need to fit on Mobo and other end fix in to the Power Button!
What it called? What it is?
Stick is offline
Old 05-03-2007, 07:10 PM   #26 (permalink)
shantanu's Avatar
Power Switch
shantanu is offline
Old 05-03-2007, 07:36 PM   #27 (permalink)
Power Switch
^^ hmmm,
you again prove >> I'm Dumbo
Stick is offline
Old 05-03-2007, 07:38 PM   #28 (permalink)
shantanu's Avatar
No buddy !!! just joking
shantanu is offline
