Old 19-02-2007, 06:12 PM   #1 (permalink)
Default dataone router settings
i ve ut300r2u router
i am using it under bridged mode
can sm1 tell me how to set it in pppoe mode
bcoz i am unable to do so by just changing the option to pppoe and saving my username and password
varunprabhakar is offline
Old 19-02-2007, 06:28 PM   #2 (permalink)
Arsenal_Gunners's Avatar
Default Re: dataone router settings
Is it working in bridge mode?
by the way
Try this
got to 192.168.1.1
choose tools
than click on MISC.
click on restore
wait for the modem to restart and see if it works.
Arsenal_Gunners is offline
Old 19-02-2007, 07:22 PM   #3 (permalink)
yea it is working in bridge mode but not in pppoe mode
Old 19-02-2007, 07:32 PM   #4 (permalink)
a_g = JPKN
s18000rpm's Avatar
refer this pic before configuring
ASUS K53SV SX520D + BF3
s18000rpm is online now
Old 19-02-2007, 07:40 PM   #5 (permalink)
i have ut300r2u starcom modem. the settings r diff here
Old 19-02-2007, 07:43 PM   #6 (permalink)
a_g = JPKN
s18000rpm's Avatar
oops sorry forgot about modem
can you upload a pic of modem's setting page.
Old 19-02-2007, 07:52 PM   #7 (permalink)
yes here is d link
http://img144.imageshack.us/img144/9485/picmk0.jpg
Old 19-02-2007, 07:56 PM   #8 (permalink)
a_g = JPKN
s18000rpm's Avatar
in the "connection type" drop-down box select PPPoE (it should be there)
Old 19-02-2007, 08:08 PM   #9 (permalink)
in connection type there r pppoe llc, pppoe vcmux
i select pppoe llc and am unable to do anything
Old 19-02-2007, 08:10 PM   #10 (permalink)
a_g = JPKN
s18000rpm's Avatar
then select the vcmux, as it had been selected in PPPoA type (frm the pic)
Old 19-02-2007, 08:12 PM   #11 (permalink)
no pppoa is default
i always select pppoe
Old 19-02-2007, 08:15 PM   #12 (permalink)
a_g = JPKN
s18000rpm's Avatar
no dude, select vcmux in PPPoE.
i said tat coz vc-mux was selected by default in pppoa type.
Old 19-02-2007, 08:36 PM   #13 (permalink)
it is connecting in pppoe llc
i can say this bcoz it shows green light when correct password is given and red light when wrong password is given.
but no site is opening
Old 19-02-2007, 08:49 PM   #14 (permalink)
a_g = JPKN
s18000rpm's Avatar
you are setting the "user name" & "password" every time you change those setting, dont you?
i'm really sorry buddy, but i have no clue about this Modem (UT300R2U) settings. b'coz in this MT880 modem there's nothing as VC-MUX, LLC...
tell me what are in the "Authentication" drop-down box.
__________
have you put the DNS values yourself??? (as frm this pic "Automatically obtain DNS" is enabled.)
Old 19-02-2007, 09:28 PM   #15 (permalink)
i ve to enter the username and password in there to connect? dont i??
Old 19-02-2007, 09:30 PM   #16 (permalink)
a_g = JPKN
s18000rpm's Avatar
yeah, i meant that every time you change those PPPoE setting, then enter the "usr /passwrd" & select-> Apply/save->Reboot modem (frm modem page)
Old 19-02-2007, 09:31 PM   #17 (permalink)
Sorry I missed out so muchI have this router.See this pic if it helps.
fill the usename in that box
After this go to tools
misc
click on save and reboot.
@S18000rpm
dude can you post a pic of advanced section in you router.
Old 19-02-2007, 09:45 PM   #18 (permalink)
a_g = JPKN
s18000rpm's Avatar
these are under "Advanced"
which page you want a screenie of
=>Advanced
-LAN Settings
-Virtual Server
-Applications
-Filters
-Firewall
-RIP
Old 19-02-2007, 09:45 PM   #19 (permalink)
go to virtual server...and post a screen
Old 19-02-2007, 09:58 PM   #20 (permalink)
a_g = JPKN
s18000rpm's Avatar
@varun -
@Vimal -
Old 19-02-2007, 10:01 PM   #21 (permalink)
Ok its the same. Here is PF tutorial for you
http://portforward.com/english/route...2/Utorrent.htm
Old 19-02-2007, 10:36 PM   #22 (permalink)
The No.1 Stupid
~Phenom~'s Avatar
^^is it the same as port triggering or this is something else ???
n00b forever...
~Phenom~ is offline
Old 19-02-2007, 10:46 PM   #23 (permalink)
no its different.Go to www.portforward.com
there is a PT tutorial also,
