Old 19-02-2007, 11:41 AM   #1 (permalink)
Default Need help guys its urgent!!!!(laptop advice)
I'm planning to buy a laptop during summer n like most of the ppl I'm confused bout which one.
I would be really grateful if u cud help me out on this one.(I live in jamshedpur...... thats in the state of Jharkhand if u dont know)
My budget is approx 57k.I need one that has a graphics card (no shared mem for graphics plzzz),OS need not be installed(I'm hopin this will keep the cost down),n most importantly a solid build(its gotta last 3 more yrs)
I haven't chked out the specific models but I've sort of zeroed in on these brands.
Dell
HP
Compaq
Lenovo
KoMbInAtIoN for Disaster
mad_hatter_11 is offline
Old 19-02-2007, 11:43 AM   #2 (permalink)
Default Re: Need help guys its urgent!!!!(laptop advice)
go for vista man and one gb should be threre
hackers2005.3721 is offline
Old 19-02-2007, 12:26 PM   #3 (permalink)
aryayush's Avatar
Your budget is a bit too low for a good graphics card.
aryayush is offline
Old 19-02-2007, 12:56 PM   #4 (permalink)
Google Bot
Pathik's Avatar
57k is too less for a gaming lappy....
if u want jus a vista capable one then a dedicated gfx card isnt a must..
Pathik is offline
Old 19-02-2007, 12:57 PM   #5 (permalink)
a_g = JPKN
s18000rpm's Avatar
in HP , only the Compaq series cater your needs- No pre-installed OS.
as all HP Pavilion Laptops come with a OS.
ASUS K53SV SX520D + BF3
s18000rpm is online now
Old 19-02-2007, 05:40 PM   #6 (permalink)
digiFriend's Avatar
for your budjet, dell inspiron 6400 is good option at rs 49,900 .e-value code Q540208. you can customise and add Nvidia or ati graphic card form dell india web-site. there are lot of customise option and will show price in real time.
after looking for laptop in all branded segment, i found this cheapest.
http://www1.ap.dell.com/content/prod...=in&l=en&s=bsd
DellTM InspironTM 6400 Notebook
Intel® CoreTM 2 Duo Processor T5500 (2MB Cache, 1.66GHz, 667MHz FSB)
Genuine Windows VistaTM Home Basic
15.4" Wide Screen XGA TFT Display (1280x800 res.)
512MB DDR2 SDRAM at 533MHz (1X512MB)
80GB1 5400RPM SATA Hard Drive
Free upgrade to 1GB 533MHz DDR2 SDRAM (2x512MB)
Free upgrade to DVD Burner
Rs 4,000 Cash Off
E-Value E-Value Code :Q540208
From
Rs.49,900
Price after savings (Price excludes taxes and delivery charge)
Expires 23-02-2007.
you never know what you can do until you try
digiFriend is offline
