Old 18-02-2007, 11:25 PM   #1 (permalink)
Default Difference between P4 3.06Ghz@533FSB and P43.0Ghz@800FSB
I want to buy a proc for my socket 478 mboard supports 800FSB
What is the Difference between
both have 1MB cache
ramu is offline
Old 19-02-2007, 11:58 AM   #2 (permalink)
deathvirus_me's Avatar
Default Re: Difference between P4 3.06Ghz@533FSB and P43.0Ghz@800FSB
Isn't it obvious ??? the later has 800 MHz FSB ... .. otherwise there is nothing much different in them ... the later one will give u slightly better performance ..
deathvirus_me is offline
Old 19-02-2007, 02:00 PM   #3 (permalink)
Sand's Avatar
i was told by one of my local vendors that the difference in performance is negligable is this correct
Sand is offline
Old 19-02-2007, 04:04 PM   #4 (permalink)
The High 5 Flyer
sam9s's Avatar
No later one would not give you better performance, unless you have the RAM to utilise it. FSB is the speed that the CPU communicates with RAM (memory). Higher FSB only increases performance when you push your RAM to fully utilises it.
FSB is always Quad Pumped the actual Bus speed. Like if your processor supports 800 FSB its actual bus speed is 200*4(Quad pumped). This means in layman tearms that you can run your memory to a max of 800 mhz, though it also depends upon the FSB/Mem ratio you set in the BIOS.
For ramu if you are running your memory to default 533, it makes no difference if you have 533FSB or 800FSB, you will feel no difference.
sam9s is offline
Old 20-02-2007, 09:45 AM   #5 (permalink)
FSB is always Quad Pumped the actual Bus speed. Like if your processor supports 800 FSB its actual bus speed is 200*4(Quad pumped). This means in a layman tearms that you can run your memory to a max of 800 mhz, though it also depends upon the FSB/Mem ratio you set in the BIOS.
I have 2x256MB --DDR400 in dual channel
so which proc should i purchase the 3.06Ghz@533 FSB or 3Ghz@800FSB
ramu is offline
Old 20-02-2007, 10:42 AM   #6 (permalink)
The High 5 Flyer
sam9s's Avatar
^^ if you are planning to use DDR 400........Pentium with 533 FSB is as good as any other......
sam9s is offline
Old 21-02-2007, 03:12 AM   #7 (permalink)
Exclamation Re: Difference between P4 3.06Ghz@533FSB and P43.0Ghz@800FSB
No matter how cool it sound .. the actual performance diff. is hardly noticeable,, ,
Old 21-02-2007, 10:40 AM   #8 (permalink)
The High 5 Flyer
sam9s's Avatar
Am I speaking spanish here................?????
sam9s is offline
Old 21-02-2007, 10:42 AM   #9 (permalink)
Well , ur not .. but that diff. in FSB is only on papers , in actual real time performance it hardly matters ...
Old 21-02-2007, 10:46 AM   #10 (permalink)
The High 5 Flyer
sam9s's Avatar
Am not sure you know what you are speaking........FSB is the MAJOR factor when is comes to pushing your RAM to its limits........neeway I respect your concepts..........so be it........EOD
sam9s is offline
Old 21-02-2007, 10:52 AM   #11 (permalink)
OK .. lets put it this way ... compare a E4300 with a E6300 ... tha later has 1066 MHz FSB , and the E4300 has just 800 MHz FSB .. so on paper , the E6300 is actually faster ... but look for some benchies ... u'll see the actual performance diff. (i mean in applications,games and not synthetic benchmarks) is hardly noticeable ...
For older CPU's , specially Pentium4's .. the main difference maker was 'HT' .. a P4 2.8 GHz HT CPU would definitely be better than a 533 MHz counterpart ... but thats it ... normal P4's would hardly make a difference ...
