Old 18-02-2007, 10:34 PM   #1 (permalink)
Exclamation RAM Upgrade.....pls help....
my motherboard is
INTEL 845G P4 2.4GHz....
384 MB DDR RAM 266 MHz (256+128)...
i'm planning to upgrade my system RAM.....
to 1GB DDR 400MHz....
is it compatible with my motherboard...
can i add my existing 256MB with this one to get 1256MB RAM....
or should i use 1GB alone....
i'm in a confusion....
pls help me out guys....
dilip_premraj is offline
Old 18-02-2007, 10:36 PM   #2 (permalink)
Arsenal_Gunners's Avatar
Default Re: RAM Upgrade.....pls help....
It does not support ddr400 http://www.intel.com/products/chipsets/845g/index.htm
Arsenal_Gunners is online now
Old 18-02-2007, 11:24 PM   #3 (permalink)
nishant_nms's Avatar
Get the 1 GB one and use it alone. U can use both of them together but they may cause troubles in worst cases. And the 1 GB 400 Mhz one will operate in 266 MHz mode
nishant_nms is offline
Old 19-02-2007, 05:35 PM   #4 (permalink)
caleb's Avatar
Originally Posted by dilip_premraj
my motherboard is
Yes it is compatible but you will only get 266Mhz out of it
__________
Yes you can use ur existing 256mb RAM and it will be 1280MB (1GB = 1024MB + 256MB = 1280MB)
__________
If you use 1GB alone or if also use the 256MB both the RAM sticks will run at 266Mhz on your mobo...so it doesn't really matter.
What you do need to see if by adding the old 256RAM is your system giving you any problems (since the new one and the old one are at different frequencies) but you have to make that decision.
About a couple of years ago I used a 512MB 266Mhz RAM along with another 512MB 400Mhz RAM (both were from different companies i.e. the old one was Dynet and the new one was Transcend) together they ran at 266Mhz on my 845GV mobo but I never faced any problems. Since it is very difficult to get a 1GB at 266Mhz RAM these days you will have to go for the 1GB at 400Mhz but try both of'em together for a day and if everything goes fine you may want to keep it both.
caleb is offline
Old 19-02-2007, 07:09 PM   #5 (permalink)
Sand's Avatar
Thanks
Evolution taught me that 'Sub kuch Chalta Hai' as long as it is 'Survival of the Fittest'! Belief in God taught me to treat everyone with kindness & respect, even if I am the fittest!
Sand is offline
Old 21-02-2007, 11:06 PM   #6 (permalink)
Exclamation Re: RAM Upgrade.....pls help....
Which one is better.....
Dynet, Hynix, Transcend...
and pls tell me the approx price for 1GB RAM 400 MHz...........
Old 21-02-2007, 11:17 PM   #7 (permalink)
caleb's Avatar
My earlier RAM was Dynet but I'm currently using Transcend and I'm not sure about Hynix.
Transcend is definately the better one but there is nothing wrong with Dynet...if you are on a tight budget go for Dynet it will save you money. Having said that Dynet will only give you 1 year warranty and Transcend will give you 3 year warranty.
caleb is offline
Old 21-02-2007, 11:22 PM   #8 (permalink)
Could u pls tell me the approx price....????
Old 21-02-2007, 11:30 PM   #9 (permalink)
caleb's Avatar
Dynet 1GB DDR 400Mhz (1 year Warranty) = Rs.3300/-
Transcend 1 GB DDR 400Mhz (1 year warranty) = Rs.3800/-
Transcend 1 GB DDR 400Mhz (3 year warranty) = Rs.4200/-
caleb is offline
Old 22-02-2007, 10:40 AM   #10 (permalink)
can anybody pls tell price of 512 mb 400 hz ddr ram thanks
EVERYBODY WANTS TO GO TO HEAVEN BUT NOBODY WANTS TO DIE
mandar5 is offline
Old 22-02-2007, 10:51 AM   #11 (permalink)
Corsair 512MB DDR400: Rs. 2600/-
Kingston: Rs. 2450/-
Transcend: Rs. 2500/-
monkey is offline
Old 22-02-2007, 12:02 PM   #12 (permalink)
thanks
mandar5 is offline
Old 22-02-2007, 08:17 PM   #13 (permalink)
Thnx buddies.....
Old 23-02-2007, 02:17 AM   #14 (permalink)
caleb's Avatar
ur welcome
caleb is offline
