| Forum |
#1 (permalink) |
Posts: n/a
I want to know which mother board for p4 should I buy, that have good inbuild chips for playing games both old and new and can run Windows vista also. Please tell me whinch mobo should I buy and their prices in Delhi. Is ati chipset mobo Intel d102ggc is ok it can play most games and will it run Windows vista smoothly or any other mobo I don't want to buy a graphics card, please reply soon. |
#2 (permalink) |
do not go for P4 opt core2duo or AMD 64 X2 and post ur budget
AMD Athlon64 2800+|ASUS K8N-VM|2GB DDR400|Corsair VX450|Seagate ST3500320AS|Samsung SV0411N|LG 22xDVDRW|LG 700S|APC ES500|Altec Lancing AVS300|Logitech MX3200|Logitech QuickCam Connect|Philips SHM6105 |
#3 (permalink) |
The G-Axe Effect
State your budget
If you are talking about serious gaming then onboard video of any kind sux. It's just meant for a low cost solution to run the OS
Graphics & Web Designer - SlideShare Portfolio & Blog : http://gxsaurav.com |
#4 (permalink) | |
CG Artist
#6 (permalink) |
a_g = JPKN
dude rit now i think only Intel's 965 series m/b have Vista compatible onboard gfx., which is GMA 3000 or GMA X3000.
if you want to run only OS (Vista) & not games, then only buy these as the GMA X3000/3000 both suck big time for gaming. i have DG965WH m/b, in intel's website its stated that this m/b has GMA X3000, but when checking thru both a s/w & DXDIAG, the report says it has GMA 3000 (not X3000) if you want to game too, then best bet for you is get a Graphics card with any of these m/b (as i think the 965 series only supports P4 [LGA 775] & C2d Procy. )
★----------�----------★ _ ★----------�----------★ |
#7 (permalink) |
Yeah ATI 102 board is good & very good onboard graphics. You will be able to play most of the games and it also runs vista nicely but the drawback is that it is not futuristic i.e do not support Core 2 Duo in case you want to upgrade in future.
Some more boards in 946 from MSI and Intel does support C2D and has same graphics onbaord [i.e GMA 3000] |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
