Old 18-02-2007, 12:08 AM   #1 (permalink)
Jack Sparrow
joey_182's Avatar
Question problems with tv tuner card
i m having asus motherboard and typhoon tv tuner card...
today i got cable wire and after completing connections and installing everything....it runs kool..but when i rebooted the pc and try to start tv..it fails to initialize hardware...
so i again reinstalled everything from starting...but again on restart same problem arises i.e fails to initialize hardware
after doing for this for 3 times..same problem is arising...
software providedby card is "easy mpeg tv tuner"...
everytime i install... program runs for only first time till i reboot...
and thing is when i restart my pc then this problem arises...
can anyone help me out...???
KHAO PIYO TE AISH KRO!!
http://twitter.com/puneetshrma
joey_182 is offline
Old 18-02-2007, 10:21 AM   #2 (permalink)
assasin's Avatar
Default Re: problems with tv tuner card
Intall ur tuner card in a diff pci slot and try.Else try ur crd in another pc or try another card in ur pc.
assasin is offline
Old 11-03-2007, 10:40 PM   #3 (permalink)
Find an update for ur driver. It shld solve the prob
_______________________________________________
One World, One People!
sudhix is offline
