| Forum |
#1 (permalink) |
Got a new comp a month back, could not over clock my due to rising temp. My case is frontech royal, 2 front fan, 2 rear fan, 1 side fan. ![]() I today opened the mobo & saw that the heat sink was not fitted properly (nehru place guys suck) I further saw that the mobo is having 4 mm sponge laid between the case & mobo , I called up the guy who fitted all my comp , he said that the mobo was getting "short' so he used it for insulation, & it wont harm it any way. But I guess it will not let the heat transfer on the other side plus if for some reason the mobo is "shorting" with case I better get that replaced, its a month old mobo & it should not have such problem. I fitted 2 front fans & 1 rear fan & one in PSU but even then my temp are quite high. IN BIOS it show that fans are not fitted where as I have at least 1 fan connected on mobo at Ch_fan2 on P5B-dlx mobo, (2 are connected from the power supply)how do enable that in BIOS? I changed the comp location to a different room right next to window but that did not help much, it was thenlowered to 48°, the ambient temp of the room is 21° yet the cpu is ranging from 52°-56° on ideal, if I use it heavily then it goes 60-67°, I event took the cabinet side covers to let the air in from all sides, that also did not get my temp below 48°. I am also having warning every 2 mins, of Vcore voltage from Asus PC probe II that the Vcore voltage is high, its ranging in 1.14v-1.30V, normally it remains 1.18v,I get warning only when it goes above 1.28v & below 1.16v Is this a false warning bcoz the in the BIOS the Vcore is set to auto & the mobo is changing it automatically? ![]() I have read the overheating thread & did not get any answers to my problem. What is causing the high temp in my case? What can I now do to lower my CPU temp ideal 45°? Where can I get in delhi artic silver 5?, I got some local thermal paste for Rs 20/- but hesitate to apply that it might be conductive to electric current. Need some direction to get this under control as in delhi summers it will fry at 40-45° ambient temp.
E6300@3.304Ghz,P5B-Dlx Wifi, 4GB Transcend DDR2 800Mhz, XFX 7600GT,Lenovo 20"Widescreen LCD, Seagate SATA2 HDD 1.5TBx2,Sony DVDRW,Creative 4.1 speakers,APC UPS 800VA,Logitech wireless mouse. Last edited by ranjan2001; 17-02-2007 at 10:15 PM. |
#3 (permalink) |
any contact no of a dealer which can courier? Quite strange that delhi is hotter than mumbai yet no one has AS5 here in delhi.
__________ OK solved the Vcore warning problem from reading on asus forum. "Go into Probe 2 and change the alert threshold to something more than 10%. The VCore voltage constantly moves between 1.08v to 1.34v on all C2D CPUs when settings are kept on Auto. This is perfectly normal." moved the setting to 20% & red warning gone.
E6300@3.304Ghz,P5B-Dlx Wifi, 4GB Transcend DDR2 800Mhz, XFX 7600GT,Lenovo 20"Widescreen LCD, Seagate SATA2 HDD 1.5TBx2,Sony DVDRW,Creative 4.1 speakers,APC UPS 800VA,Logitech wireless mouse. Last edited by ranjan2001; 17-02-2007 at 10:24 PM. Reason: Automerged Doublepost |
#4 (permalink) |
yup apply arctic silver 5 or even arctic ceramique will do ..
keep those 2 front and 1 side fan as intake fans .. and 2 rear fans in the back as outlet .. and properly fit ur heatsink on cpu .. and see what happens .. |
#5 (permalink) | |
E6300@3.304Ghz,P5B-Dlx Wifi, 4GB Transcend DDR2 800Mhz, XFX 7600GT,Lenovo 20"Widescreen LCD, Seagate SATA2 HDD 1.5TBx2,Sony DVDRW,Creative 4.1 speakers,APC UPS 800VA,Logitech wireless mouse. |
#6 (permalink) |
Make sure u disable "Automatic QFan Control" in the bios .. or any target temp that u might have set ...
Also , the voltage can fluctuate when set to auto .. for a CPU running at stock .. i'd recommend u to try some permanent voltage between 1.2 and 1.25 ... u don't need anything more for a C2D at stock .. i'm running mine oc'ed at 3.02 GHz with only 1.25V |
#7 (permalink) |
I have not set any target temp & Qfan is disabled & not installed, voltage problem is solved.
I will try removing the sponge & take the mobo out & use barebone PC in open air keeping it on a non conductive surface &then monitor the temp.
#8 (permalink) |
a_g = JPKN
ranjan dude first of all get rid of that punk A$$ Zebronics PSU. & get a better one.
i cant believe it, you bought a Zebronics PSU for a ASUS P5B Dlx Wifi & if you got any Overclocking plans, dont do it with the Zebronics. & i've a doubt, if the m/b is shorting, then is it a problem with m/b or PSU+earthing or cabinet+PSU+earthing???
★----------�----------★ _ ★----------�----------★ |
#9 (permalink) |
First of all delhi or North India for that matter is shiiit. Even if they have arctic silver, they will mix it with something & sell you the local thermal paint at cost of original.
Motherboard shorting with cabinet?? That was something 5 years back. Now that sheet is not required to be placed. Your outdated assembler will screw ur system. Earthing provisions have now been built in the motherboards [mounting holes]. Hope that your mobo is not mounted directly instead it uses brass mounting studs underneath mobo. Every cabinet including Zebronics have that provisions. You can have a look at Antec Super Lanboy [aluminium cabinet], Al is better in dissipating heat. |
#10 (permalink) | |
It seems that the guy who assembled my comp has screwed up in a big way, I remember that there were special screws with the mobo but the board is not having any of those screws at all, instead he used local screw all different sizes.
__________ Quote:
I could not find any good power supply here in nehru place, here we discuss coolermaster / powersafe etc but these things are not easily available in shops. I have no plans of overclocking till I get this temp under control. __________ next day updated I opened the mobo & got to know some shocking facts, before that see the images which I want to ensure that heat sink was seated fine. ![]() The rear side mounted confirms the same ![]() Then I checked further & found that the center is pushed down either due to Heatsink weight or design defect. Is that normal happening???? ![]() This definitely will short with the body when its mounted, bcoz the center part is dugged 3-4mm deeper I then opened the heatsink to check the thermal paste, hope this is fine too. ![]() Then I gave a serious thought & remember that the mobo or the cabinet had some insulated mounts which were suppose to be fitted below the mobo & they were missing & due to that the mobo was tilted right side 6 mm to one side , bcoz the back (left) panel was lifted to fit within the USB slots, in that case its bound to touch the metal body & create shot circuit .................................this duffer who fitted my comp insulated it with 5mm sponge & that was trapping the heat badly. I made a local jugad (since its sunday) with double sided tape & made a insulated mount which can lift the mobo so it does not touch the body & removed that sponge & booted in bios to watch the hardware temp. I did that & Voila..................................!!!!!!! ............I booted successfully for the 1st time with 43° ideal temp & now running at overclocked 2.3Ghz.with 50° ideal temp. ![]() Now tomorrow 1st thing I go & kick the guys ass who did that blunder with the fitting & get my insulated 6mm mounts to get the board running as it should have been from the 1st day. ALL HEATING PROBLEMS BE SOLVED THEN. Thanks guys for helping out it was a real nightmare for me last few days sorting this temp issue.
E6300@3.304Ghz,P5B-Dlx Wifi, 4GB Transcend DDR2 800Mhz, XFX 7600GT,Lenovo 20"Widescreen LCD, Seagate SATA2 HDD 1.5TBx2,Sony DVDRW,Creative 4.1 speakers,APC UPS 800VA,Logitech wireless mouse. Last edited by ranjan2001; 18-02-2007 at 04:59 PM. Reason: Automerged Doublepost |
#11 (permalink) |
a_g = JPKN
i'm glad your problem's solved
btw these are the BRASS Mounts which were provided with Zebronics AntiBiotic cabinet -- ![]() Zebronics povides lots of Screws, these Brass Mounts... So ask your Assembler for those.
#12 (permalink) |
Yes these were there in a packet which he should have used to mount the mobo, but he did not .....................I am going to fire him up tomorrow 1st thing in the morning.
#13 (permalink) |
The Thread Killer >:)
Wow! Great troubleshooting dude!! If you hadn't detected this, your mobo and proccy would have been fried in a month for sure. Blast that guy and get something for compensation, if not, don't think twice to thrash him
Want to make this world a better place? Then, start seeding and don't be just a leecher |
#14 (permalink) |
Sure it would have fried as the summer approaches here in delhi the ambient temp in the room goes 38-40°, in that case it would start giving me problem....................gud that I got this sorted out.
Tomorrow I will buy some extra mounts & fit that in the cabinet.
#15 (permalink) | |
So many studs & screws come with Zebronics cabinets. Ask him to explain, why did he put that sponge sheet. It is strange that such ignorant people get into this business of assembling. This happens only in Delhi. |
#16 (permalink) |
I finally got the original screws directly from the company (frontech)as this bugger had lost it & kept on saying that these screw do not work with ur mobo.
I then fitted the mobo yesterday & now its 6mm away from the cabinet. My heat problem is partly solved but I am still running high by 8-10° @ 62° overclocked at 450 FSB What else could be wrong as I am told that the ideal temp even overclocked should be within 50-52°.
#17 (permalink) |
@s18000rpm
Zebronics 400W PSU is not that bad. Its working fine for me. This sites reccomends at least a 500 to 550W one for my PC but Zeb 400W is fine at even full load.
G1: PII X4 B50 4.0 | TRUE 120*2 | TA790GXB A2+ | 4GB DDR2 GSkill 1200 | Audigy 2 | HD4870 | HEC 550 | MX 518. G2: AII 240 | M2N 68AM+ | 3GB| 8800GT | Zebby Plat 500 G3: XPS M1530 | FZ 16. |
#18 (permalink) |
After trying many options, I called up intel/asus & they both have asked to check the respective cpu/mobo to ensure that they are fine , if not then they will replace, but this will take at least 4 days for them to revert back.
Intel has asked me to get the cpu to check on another intel board & asus will self test on its testing bench. hope they can find some fault & replace the faulty unit.
#19 (permalink) |
last few days update is that the Vendor Comnet vision tell me that I need to have a better power supply since 7600GT needs that & they say that CPU heating is due to low wattage of my so called Zebronics 400 watt smps. So before taking up the matter with Intel /asus they want to testthis with the following.
They have suggested me the following. ![]() Antec Performance TX 1088B http://www.antec.com/us/productDetai...?ProdID=61050# & the following power supply to choose from. Earth watts 500 ![]() http://www.antec.com/us/productDetai...?ProdID=27500# or Neo HE 500 watt ![]() http://www.antec.com/us/productDetails.php?ProdID=28500 What do u guys think of this combination, will it solve my cpu heating problem? Is it really due to low watts of my SMPS that cpu gets heated up? Which one should I buy for my system (config is in my signature)
E6300@3.304Ghz,P5B-Dlx Wifi, 4GB Transcend DDR2 800Mhz, XFX 7600GT,Lenovo 20"Widescreen LCD, Seagate SATA2 HDD 1.5TBx2,Sony DVDRW,Creative 4.1 speakers,APC UPS 800VA,Logitech wireless mouse. Last edited by ranjan2001; 01-03-2007 at 08:08 PM. |
#20 (permalink) | |
The High 5 Flyer
You can go for antec, though I strongly feel they are badly overpriced. A powersafe or VIP psu are very best options given under the budget. PS :: The last time where we left the story was you geting checked both your CPU and Board by an authorized engg, I was looking upon our official CPU OC club thread where we left. But nee way we can continue here....so whats the latest
sam9s NAS Project! powered by Unraid! (Corrected!) sam9s HTPC Project! powered by XBMC! sam9s i7 Powered by Sandybridge! My XBMC Collection Last edited by sam9s; 01-03-2007 at 09:20 PM. |
#21 (permalink) |
Hi sam, they are arranging thsi at their own cost , if this solves he problem only then I will buy it, & yes its quite overpriced.
Last few days I tried searching for powersafe, but no one knows about this brand in Nehru place. I dont know if some store in mumbai can ship it to me or not, NP is a useless market (biggest computer market they claim) & u dont get what u want, mostly they want u to buy what they want to sell. Even Zebronics have some high end SMPS, but again the same story ..........u dont get what u want in nehru place.
#22 (permalink) |
a_g = JPKN
[off topic]
Sam dude, pls clear/delete msgs. from your PM inbox. i tried to PM you several times. [/off topic]
#23 (permalink) | ||
The High 5 Flyer
Neeway you wont get powersafe from NP, you wont even get any authorized dealer in delhi, unfortunately you gotta get it from down south, I got it from one of my friends in bangalore. VIP I am not sure if they have any authorized dealer in delhi. Google it...... you will find it if its there. __________ Quote:
sam9s NAS Project! powered by Unraid! (Corrected!) sam9s HTPC Project! powered by XBMC! sam9s i7 Powered by Sandybridge! My XBMC Collection Last edited by sam9s; 01-03-2007 at 09:47 PM. Reason: Automerged Doublepost |
#24 (permalink) |
I wrote to asus & this is what they replied.
The temperature is normal. For CPU temperature, if it is below 75C degree, it is normal. If the motherboard temperature is below 60C degree, it is normal. Please don't worry about the temperature. If you have any problem, please refer FAQ(Frequently Asked Questions) or contact us again. We will try our best to help you. I really dont know what else could be done? most of the users report 35-45° ideal temp so compared to that mine is surely high & if I overclock it reaches 74°C on full load, which is not good for 24x7 usage. -------------------- I still wonder how a better power supply will solve this issue? What does PSU have to do with CPU overheating, is there any connection? It will take 10 days for the dealer to get the antec PSU & I am getting a feeling it will not solve the problem
E6300@3.304Ghz,P5B-Dlx Wifi, 4GB Transcend DDR2 800Mhz, XFX 7600GT,Lenovo 20"Widescreen LCD, Seagate SATA2 HDD 1.5TBx2,Sony DVDRW,Creative 4.1 speakers,APC UPS 800VA,Logitech wireless mouse. Last edited by ranjan2001; 03-03-2007 at 09:51 AM. |
#25 (permalink) |
a_g = JPKN
if possible try to get a PSU from any of your Friends & test.
or does any friend of yours have similar config, so that you can test your Processor/PSU on theirs' & vice-versa
#26 (permalink) | |
The High 5 Flyer
Ranjan I read u saying 74C OC at full load. This is acceptable coz even mine reaches 72-74 at 100% Load (through TAT). Nobody is gonna tax the CPU at 100% in normal conditions (even if you try......a C2D does not cross ~60-70% with 15 applications opened simultatiously. Its ony when you do video encoading, editing, rendering or play a heavy game for that matter.... you make your C2D touch 100%, and this not something you will do 24x7. Now coming to the idle temp, which I feel should not be more than 50C, and that could be a point of concern for 24x7 use (like while downloading movies and stuff). If you are crossing 55 idle temp then you can try few steps to bring it down below 55. If its like 52-54 as I think it is, I say no worries.
sam9s NAS Project! powered by Unraid! (Corrected!) sam9s HTPC Project! powered by XBMC! sam9s i7 Powered by Sandybridge! My XBMC Collection Last edited by sam9s; 03-03-2007 at 02:06 PM. |
#27 (permalink) |
Sam I got finally today Zebronics Peace cabinet & Zeb 500 watt platinum power supply & eagerly changed the mobo & hdd to the new caby...................................but but but my temp still remain the same 50-54 ideal, no over clocking at all & at fullload (No OC applied) TAT load test makes it 74-76C, that too high.
This PSU gets mounted upside down so the big fan air flow is downwards, I am not sure ifthats ok or not, I feel it should be upwards. http://zebronics.net/images/power/zeb-500w-2led-b.jpg If I OC then it will go beyong 60 ideal & at full load 80-85C, I also tested another graphic card just in case that might be the cause, but no chnage in ideal temp. Its surely either the mobo or the intel heat sink seems to be faulty, though my test images show it looks fine. Now the only 2 things left are intel HSF & asus mobo.................cant think of anything else.
E6300@3.304Ghz,P5B-Dlx Wifi, 4GB Transcend DDR2 800Mhz, XFX 7600GT,Lenovo 20"Widescreen LCD, Seagate SATA2 HDD 1.5TBx2,Sony DVDRW,Creative 4.1 speakers,APC UPS 800VA,Logitech wireless mouse. Last edited by ranjan2001; 06-03-2007 at 10:47 PM. |
#28 (permalink) |
a_g = JPKN
about PSU
i think thats the correct position
#29 (permalink) | |
The High 5 Flyer
Now this can be due to environmental factors as well, My system is kept close to window, far from the television, and there is proper ventilation. Try this......take you system to another room and then note the temps, I think it should show a difference of 3-4 C. Also I hope you are using TAT for measuring temps. I am attaching some snaps of my system to give you some relief..... ![]() My config... ![]() TAT Ideal Temp ![]() TAT 100% Load |
#30 (permalink) | |
Sam, Ur temp shows 56C ideal when over clocked but mine shows 52-54C non overclocked, let me try tomorrow same over clocking then I post back the findings.
BTW r u back in delhi ? Quote:
| Bookmarks |
| Thread Tools | |
| Display Modes | |
