Old 17-02-2007, 04:17 PM   #1 (permalink)
tango_cash's Avatar
Default my laptop hibernates when i switch it on
hi i have a dell latitude d510 laptop. today when i started it then after the booting the laptop it went into hibernation. it just wont stop,every time i start it it loads the windows xp it comes to the desktop and before i can do anything it goes into hibernation.
pls help.
tango_cash is offline
Old 17-02-2007, 04:45 PM   #2 (permalink)
Laptoping
Sourabh's Avatar
Default Re: my laptop hibernates when i switch it on
Make sure the battery is charged enough. Plug it to the mains before you power on the laptop the next time and boot into safe mode by pressing F8 before it gets into windows. Disable Hibernation, alarms from the power options and restart. If there is no option to disable hibernation in Safe mode, wait for some time to rule out the problem with the hardware.
Sourabh is offline
Old 17-02-2007, 06:14 PM   #3 (permalink)
shashank4u's Avatar
how the problem have come from nowhere..
try system restore..
Be like a postage stamp-stick to one thing until you get there.
shashank4u is offline
Old 18-02-2007, 07:27 PM   #4 (permalink)
Post Re: my laptop hibernates when i switch it on
Does your laptop charges properly and the uptime without power is adequate. ? If no thenyou need to get your battery checked and maybe changed.It happens with some xp security patches download also.
nirusam is offline
Old 18-02-2007, 08:12 PM   #5 (permalink)
nishant_nms's Avatar
Disable hibernation and tell what happens then any unusuall massage or the battery dies
nishant_nms is offline
