Old 14-02-2007, 11:57 PM   #1 (permalink)
anarchy0x's Avatar
Default weird hardware problem!!
ok now this is really weird, my motherboard intel 865 GBF stopped working suddenly 1 day, it wudnt boot so i called my mechanic, he fixed it n left it at my place, when i tried to boot up the machine the same porblem came up, i called him up n he told me that he forgot to "short" the motherboard on button (watever that means) & told me to put a screw driver on the pins (9 pins on the extreme bottom right of my MOBO on a white plastic) I did that n it started working but then suddenly after a while i had the same problem but when i wud turn the cpu on the fan wud start n wudnt stop but there wasnt any display on the screen, so i called him up again, he told me to take the HDD connections out of the MOBO n start the pc , shut it & again put the connections back & start it again,n that worked
now my pc works for while then it either restarts or shuts down by itself n i have 2 do 1 of the 2 things that i ve mentioned 2 start it again... help me out with this!
anarchy0x is offline
Old 15-02-2007, 12:01 AM   #2 (permalink)
a_g = JPKN
s18000rpm's Avatar
Default Re: weird hardware problem!!
did you mess with the BIOS???
coz i did & faced a similar problm. the CPU fan was spinning very fast, but no boot/display.
i had to put the BIOS jumper in config mode & reverted to Default settings.
__
s18000rpm is offline
Old 15-02-2007, 12:06 AM   #3 (permalink)
Arsenal_Gunners's Avatar
Call that dude and get it fixed,how can a engineer just leave all this in a mess.
Arsenal_Gunners is offline
Old 15-02-2007, 12:59 AM   #4 (permalink)
Google Bot
Pathik's Avatar
its jus cos ur power button is not connected or welded to ur mobo properly.. Tell him to come n do it
Pathik is offline
Old 15-02-2007, 01:12 AM   #5 (permalink)
anarchy0x's Avatar
i will call him but thething is it ll take a lot of time, cant i do anything 2 fix it? like do i hav 2 change a bios value??
Old 15-02-2007, 01:19 AM   #6 (permalink)
Google Bot
Pathik's Avatar
imho it isnt a bios problem but a hardware one
Pathik is offline
