12-02-2007, 11:29 PM
The No.1 Stupid
How to see bad sectors in XP ??
Hi,
I know the new name of SCANDISK in 98 is CHKDSK in XP. But with SCANDISK in 98 , we could also see the bad sectors , which is unavailable in XP.
Actually the problem is my kingston pen drive has got bad sectors( I know it coz the data gets corrupted quite often and only reformat helps), its in 5 year warranty but to get it replaced I need to show my dealer that it has bad sectors coz earlier when I took my corrupted pen drive to him , he formatted it and said its working fine. Now I wanna show him the bad sectors , I m using XP SP2 , how can I do that ????
n00b forever...
12-02-2007, 11:40 PM
Alive Again...
Re: How to see bad sectors in XP ??
me too want to ask same thing...........
12-02-2007, 11:48 PM
12-02-2007, 11:53 PM
The No.1 Stupid
^^we know this , but what we want is to see the bad sectors visually on screen , just like in SCANDISK.
n00b forever...
12-02-2007, 11:56 PM
oh,Will a 3rd party software do?
13-02-2007, 12:08 AM
The No.1 Stupid
yeah ,sure anything will do.
n00b forever...
13-02-2007, 12:10 AM
Ok,I ll try to search it.
13-02-2007, 12:28 AM
The No.1 Stupid
ok , lemme make it bit easier for ya. I need anything which shows/confirms/proves that my pen drive has bad sectors.
n00b forever...
13-02-2007, 12:33 AM
13-02-2007, 12:45 AM
The No.1 Stupid
^^ sorry to say but it didnt helped.
n00b forever...
13-02-2007, 12:57 AM
13-02-2007, 11:52 AM
Get the freeware HD Tune from www.hdtune.com and in this run the error scan - this shows a visual screen of the HDD's surface being scanned and shows the bad sectors.
13-02-2007, 12:31 PM
The High 5 Flyer
Originally Posted by ~Phenom~
Hi,
Scandisk is a DOS utility, you need to boot to DOS to get it worked. For that either use a DOS FDD or CD. Boot to DOS and from the A prompt type A:/>scandisk/s c: or c:/>scandisk/s this would run a surface scan on c drive with pictorial representation just like you want. However I am not sure if DOS would recogonise the pen drive letter, try that out, if it does you can run the scandisk on your pen drive as well.
13-02-2007, 01:26 PM
Reason: Automerged Doublepost
13-02-2007, 02:56 PM
Microsoft MVP
I think chkdsk /r will detect the BAD sectors.
U can also try 3rd party utilities, like:
Everest Home edition
Partition magic
Norton disk doctor
Disk checker
Drive health
13-02-2007, 04:07 PM
The No.1 Stupid
@vimal , ur hard drive mechanic is giving extended memory handler error. My HDD is 250 GB.
@Eazy , ur software is good.
@sam9s, I can do it ur way , but it will not detect my pen drive, so of no use.
@ismart , thanx but I already have those tools , and they dont dont serve the desired purpose.
@vishal , ur method will check and remove bad sectors automatically , but will not tell if there were/are bad sectors in the drive.
n00b forever...
16-02-2007, 03:32 PM
your question is the best one..and i will try...
