Old 12-02-2007, 02:18 AM   #1 (permalink)
ayush_chh's Avatar
Default 160 minus 30 (hdd problem)
i bought a SATA1 HDD recently, 160 GB and installed it. i can see 160GB in BIOS but after installation only 130GB is available where is my 30GB...please help
eXPerience is what a MAN learn's fROM.....
ayush_chh is offline
Old 12-02-2007, 02:22 AM   #2 (permalink)
-The BlacKCoaT Operative-
Rollercoaster's Avatar
Default Re: 160 minus 30 (hdd problem)
most prob u messed up with patitions...
btw the actual available size of 160GB is ~150GB
Rollercoaster is offline
Old 12-02-2007, 10:10 AM   #3 (permalink)
Resident Fanatic
Manshahia's Avatar
Yeah the more the partitions, the less the space u r getting.
Manshahia is offline
Old 12-02-2007, 10:34 AM   #4 (permalink)
Eazy's Avatar
Which version of Windows have you installed. If it is XP then you need to install Service Pack 1 or 2 to get the OS to recognise HDDs over 127GB. This size limitation can also be there from the Mother Boards HDD controller to which the HDD is connected - this will be the case if the Mother Board is an older one.
Eazy is offline
Old 12-02-2007, 06:25 PM   #5 (permalink)
digiFriend's Avatar
as your bios has detected 160 gb, mother board has not problem.
(if your operating system is using "36 bit LBA" then maximun harddisk size it can detect is 127.4 GB.to detect more than 127.4 GB ,the OS need "48 bit LBA")
2)download "EnableBigLba.exe" its size is 156 kb and its freeware. run it and it will make LBA 48 bit. reboot.
3)or to manually do it.
* regedit
* HKey_Local_Machine\system\current Control set\services\atapi\parameters
* find "EnableBigLBA" there and change it value to 1.(if it is not there,write it and make its value 1)
* exit Regedit and reboot.
(note: installing new SP2 patch can also fix this problem.)
you never know what you can do until you try
digiFriend is offline
Old 12-02-2007, 06:51 PM   #6 (permalink)
The Unknown's Avatar
Probably you did not partition your HDD properly. Goto start=>run type compmgmt.msc and select disk management in the left window and see the details. If any space is remaining, try creating a new partition. If u have SP 1, i am not sure abt compmgmt.msc Mine is SP2 and to partition my HDDs, i use the stated method.
KDE on ArchLinux
The Unknown is offline
Old 12-02-2007, 07:41 PM   #7 (permalink)
Still in war with allies
ssdivisiongermany1933's Avatar
U get 149 GB on 160 GB , its approx loss of 5.62 % .Use any disk management software
ssdivisiongermany1933 is offline
Old 21-02-2007, 05:19 PM   #8 (permalink)
ayush_chh's Avatar
i think we get 152 GB in a 160GB HDD. there is no problem in my partitioning the HDD. i have win XP with sp2. my mobo is intel 946......while partion it shows only 127 GB as told by 'digifriend'......i m goin to try his reply.....thnx
Old 25-02-2007, 11:23 PM   #9 (permalink)
ayush_chh's Avatar
OK....i got the space....thanks to digifriend......i got a total of around 149 GB.
