Old 10-02-2007, 06:27 PM   #1 (permalink)
The Unknown's Avatar
Smile HDD????????? Which to buy?
Hello, i am thinking to buy a new HDD of 40 GB. I already have 50(10+40)GB in my pc. I just wanted to know that whether it will work in my pc with the following conf.:
Pentium 3 500 Mhz
Intel i810 graphics
10/100 Lan
(10GB+40GB)HDD already installed
AC'97 Sound
52x(CD-R WRITE)/32x(CD-RW)/52x(READ) CD RW Sony
8 USB Ports
Windows Xp
Power Supply Unit- 450 Watts
Possibly another lan card to be added and linux loaded.
On the abv conf. suggest which one to buy, i.e. internal/external
Also suggest company. I would like to buy Segate only.
For internal i have Secondary Slave IDE port empty.
Thanks in advance.
KDE on ArchLinux
The Unknown is offline
Old 10-02-2007, 07:01 PM   #2 (permalink)
Noobie Pro
alsiladka's Avatar
Default Re: HDD????????? Which to buy?
Well, If you have an IDE port empty, you can attach a new hard drive. Why dont you go for something more than 40GB? now a days rates of hard drives are pretty low.
www.twitter.com/alsiladka
alsiladka is offline
Old 10-02-2007, 07:16 PM   #3 (permalink)
nishant_nms's Avatar
I would suggest for going for a extenal one means an internal drive in external casing as it will provide mobility too
nishant_nms is offline
Old 10-02-2007, 11:30 PM   #4 (permalink)
The PSU should take the load na! If it doesn't, what's the use?
__________
Originally Posted by nishant_nms
I would suggest for going for a external one means an internal drive in external casing as it will provide mobility too
I don't move hdds. To move data, i just upload it to the www & distribute. Also internal hdds are cheap.
KDE on ArchLinux
Old 11-02-2007, 05:59 PM   #5 (permalink)
^^I sugested an internal one with a external casing it will cost u only 200 more with mobility as a bonus feature
And I think ur PSU can take load of an another drive too
Old 11-02-2007, 07:03 PM   #6 (permalink)
Question Re: HDD????????? Which to buy?
OK, GOOD TIP BUT PSU WILL SUPPORT WHICH ONE INTERNAL/EXTERNAL
KDE on ArchLinux
Old 12-02-2007, 12:01 AM   #7 (permalink)
As u have posted u have 450 Watt SU so it can take load of any one of them
