Old 10-02-2007, 12:53 PM   #1 (permalink)
g_goyal2000's Avatar
Default System restarts when loading FarCry
Hi.
I installed the game FarCry from my original CD's along with it's patch v1.4 yesterday & was running fine without any problems.
But today, when I'm trying to run the game, while loading any level, the system restarts.
I have previously installed & played the same game 5-6 times successfully.
I don't know what happenned.
I haven't done any changes to the system since I installed the game.
Kindly help.
Dell Studio 1558, Intel i5 M430 @ 2.27 Ghz, 4 GB RAM, 1 GB ATI 5470 Mobility, 500 GB HDD, IDT HD Audio with Creative X-Fi MB software
g_goyal2000 is offline
Old 11-02-2007, 10:23 AM   #2 (permalink)
Stalker's Avatar
Default Re: System restarts when loading FarCry
did this problem occur after u patched the game??
try updating ur gfx card drivers, reinstall the game...
| C2Q Q6600 G0 | Intel DG33FB | 4 GB Corsair 6400C5G DDR2-800Mhz | XFX 8800GTX | CM Extremepower 600W | 250GB Seagate HDD | Lite-ON 1635S DVD RW | Logitech MX-518 | Zalman RS6F | APC RS 800 |
Stalker is offline
Old 11-02-2007, 01:33 PM   #3 (permalink)
rajasekharan's Avatar
i guess only reinstall helps...
Make a day good , and another day good , and another ...a happy lad is "born" from you :)
rajasekharan is offline
Old 11-02-2007, 01:38 PM   #4 (permalink)
This is the first time this problem has occurred.
I had played the game with this patch previously too & never faced this problem.
I have the latest updated drivers for all of my hardware.
2 months ago, my hard disk had crashed.
So, I was given a replacement hard disk.
Could the problem be because of the new hard disk?
My game loads fine but when starting any level, the system restarts.
I have to reload the game 3-4 times before it eventually runs fine.
I have checked the hard disk for problems & it shows non.
Old 11-02-2007, 01:56 PM   #5 (permalink)
GUNNING DOWN TEAMS
wizrulz's Avatar
cant say what it is..but i i had similar problem with BIA...BROTHER IN ARMS...for every new new level ..i had to live ssame way and coplete the game..could not find any solution either....try uninstalling and then reinstalling it...in different drive...mi8 help u
wizrulz is offline
Old 11-02-2007, 02:08 PM   #6 (permalink)
Jack Sparrow
joey_182's Avatar
well same is the case with my frnd also....
at that time i didnt found any solution but i guess this is due to AMD processor...
as we know processor is fast but cant load this high graphics...and farcry is two heavy for AMD..and when next u enter to next level the processor has to load all the setup..and AMD here fails to load again....my frnd also having AMD..
but solution to this is dont run any other application when u r playing far cry..
KHAO PIYO TE AISH KRO!!
http://twitter.com/puneetshrma
joey_182 is offline
Old 11-02-2007, 02:12 PM   #7 (permalink)
GUNNING DOWN TEAMS
wizrulz's Avatar
Dude do u know FAR CRY was made for AMD.............
wizrulz is offline
Old 11-02-2007, 02:33 PM   #8 (permalink)
Jack Sparrow
joey_182's Avatar
ya..buddy..
but it runs much smoother on intel....
__________
on intel's D845
joey_182 is offline
Old 11-02-2007, 04:51 PM   #9 (permalink)
Try this ,
1.First make a back up of ur Far Cry save game
2.Next Uninstall the game and delete all the files in the Far Cry folder ,
3.Download the latest nVIDIA drivers and uninstall ur old drivers
4.Next install the newly downloaded drivers and install the game and all its patches.
Now try to Run the game, and do post the result
raskal00 is offline
Old 12-02-2007, 01:48 PM   #10 (permalink)
Like, I said I have latest processor, graphics, soundcard & mobo drivers as well as firmware installed.
I have played the same game 5-6 times successfully before.
I bought the game in August 2005 & have been playing it ever since successfully without any problems on the same computer configuration I currently have.
I have played heavier games than Farcry also but never faced this problem with any of them.
