Old 09-02-2007, 08:52 PM   #1 (permalink)
Sup' dude, Sup'
Default liteon LH-16a1p not reading any cd.
After burning DVD, i am unable to see content in the disc. But can see the content in other drive. writer is liteon 16x super all write. media is moserbaer.
ambandla is offline
Old 09-02-2007, 09:32 PM   #2 (permalink)
Security Exp
47shailesh's Avatar
Default Re: burning issues
Upgrade the firmware.....
We Love Once, And When We do We do it Well
47shailesh is offline
Old 09-02-2007, 09:39 PM   #3 (permalink)
shantanu's Avatar
and or check your OS and Cables for problem
shantanu is offline
Old 11-02-2007, 09:59 PM   #4 (permalink)
The Transcendental
Can you read some other dvd with the burner?
Maybe the reading function of your DVD burner is gone and the writing part is still there. Different power lasers are used for reading/writing.
:::::::::: When freedom is outlawed, only outlaws will have freedom ::::::::::
..:: Free Radical ::.. is offline
Old 14-02-2007, 12:37 AM   #5 (permalink)
Sup' dude, Sup'
dvd's are working fine now but it is not reading cd's. model number is Liteon LH-16a1p. Unable to find firmware on the web. even liteon didn't provide that.
ambandla is offline
Old 14-02-2007, 01:53 AM   #6 (permalink)
 Macboy
goobimama's Avatar
Try a different DVD. Get a mixture of cheap/expensive DVDs and check em out. My writer couldn't write to MoserBaer, I got it replaced though...
I'm like a bird... :)
goobimama is offline
Old 14-02-2007, 06:49 AM   #7 (permalink)
Sup' dude, Sup'
how much time will it take to replace a writer?
ambandla is offline
Old 14-02-2007, 01:05 PM   #8 (permalink)
 Macboy
goobimama's Avatar
Since mine was under warranty (still is and will be for another two and half years), i just called up my guy and he got a replacement piece...
Not sure how good your side of the world is with replacements n all...though you should be having 1 year warranty..
Old 14-02-2007, 06:53 PM   #9 (permalink)
Sup' dude, Sup'
mine is just a month old. can u give me support contact number for liteon
ambandla is offline
Old 14-02-2007, 07:07 PM   #10 (permalink)
 Macboy
goobimama's Avatar
Who did you buy it from? Ask your local PC walla to take care of it. No need to go to Lite-on directly. Of course, if you have bought it from abroad, you are 5kr3M3D (Screwed)...
