Old 09-02-2007, 08:40 PM   #1 (permalink)
Chetan1991's Avatar
Question CD-RW 'OK' but DVD-RAM 'CRC' ?????
Hi friends! I have a CD-RW drive and a DVD-RAM drive.There are some files written by CD-RW which the CD-RW copies but DVD-RAM doesn't and shows "Cyclic Reduntary Check" error.Why is this so? ?Pls help!!!
Chetan1991 is offline
Old 09-02-2007, 08:51 PM   #2 (permalink)
Super Hero - Super Powers
n2casey's Avatar
Default Re: CD-RW 'OK' but DVD-RAM 'CRC' ?????
Which company's CD-RW & DVD-RAM drive r u using??
Minds are like Parachutes :arrow: They work best when open
n2casey is offline
Old 09-02-2007, 08:53 PM   #3 (permalink)
Chetan1991's Avatar
Well CD-RW is of LG and DVD-RAM of Sony
Old 06-03-2007, 10:44 PM   #4 (permalink)
Chetan1991's Avatar
Hey!! answer me!!!
Old 06-03-2007, 10:49 PM   #5 (permalink)
shantanu's Avatar
there can be many thing... your PSU is not providing with the adequate power to both drives.. just disconnect extra hardware from the system and try again.. if then also problem persists then take your DVD-RW(RAM) drive to the service station..
shantanu is offline
Old 06-03-2007, 11:07 PM   #6 (permalink)
assasin's Avatar
Before taking it to service center just flash the dvd rw drive's firmware.sud solve ur problem.Also check if master slave jumper setting r ok.
assasin is offline
