Old 09-02-2007, 02:44 PM   #1 (permalink)
Default powerful desktop or around rs50000 laptop???
im confused which one to buy.my budget is around rs50000.i have an old compaq desktop.should i go for a new desktop or a laptop.i watch quiet a bit of t.v. on my desktop and i want the laptop to do the same job for me.other than watching t.v. i do surfing,listen to music and occasionally play some game.i want to have vista.will the laptop be able to staisfy the requirements of the vista??
or
i should buy a new lcd screen for watching t.v. and movies and stick to my old desktop and xp.kindly help!!!
deepinder_mann1988 is offline
Old 09-02-2007, 02:48 PM   #2 (permalink)
Arsenal_Gunners's Avatar
Default Re: powerful desktop or around rs50000 laptop???
Dude It makes sense to buy a laptop only if you need a computer on wheels.
Arsenal_Gunners is online now
Old 09-02-2007, 02:55 PM   #3 (permalink)
Google Bot
Pathik's Avatar
depends on ur requirements...
i wd prefer a power packed pc tho.
Pathik is offline
Old 09-02-2007, 09:29 PM   #4 (permalink)
Tux Fan
shaunak's Avatar
On the left side of the ring, weighing in 2ghz dual core a full fledged fire breathing number pulverising monster who will preform no matter what.
And his opponent a slim flimsy laptop which will sucumb to even doom '93 ~.
The choice is obvious.
Cheers
Shaunak
Feel free to PM/email me.
shaunak is offline
Old 09-02-2007, 09:42 PM   #5 (permalink)
Tech Geek's Avatar
If you want a laptop go for DELL INSPIRON 6400
It will exceed 50K by more 5-6K
Tech Geek is offline
Old 09-02-2007, 10:08 PM   #6 (permalink)
Mclaren F1 Long tail
aneesh kalra's Avatar
yes buy a laptop only if you are on the move constantly because upgrading components in a laptop is both limited and expensive .
Computers are like air conditioners. They work fine until you start opening windows.
aneesh kalra is offline
Old 09-02-2007, 10:13 PM   #7 (permalink)
shantanu's Avatar
In 50000 you can get a great lappy and deskky .. choose wisely
shantanu is offline
Old 10-02-2007, 01:08 AM   #8 (permalink)
 Macboy
goobimama's Avatar
Get a laptop ONLY if you need the portability. Otherwise, nothing can match the performance, maintenance, upgrading, and the overall comfort of using a desktop...
I've seen this trend lately, people buying laptops for the sake of buying one... end up using it as a desktop.
I'm like a bird... :)
goobimama is offline
Old 10-02-2007, 01:14 AM   #9 (permalink)
shantanu's Avatar
You can go for Dell/Lenovo with good configs.. and yes you cant get that upgradibility which you can get in Desktop.
shantanu is offline
