Old 09-02-2007, 11:02 AM   #1 (permalink)
mak1012's Avatar
Question checksum??????
hi,
guys.....when i start my pc it doent boot and gives a an error "cmos check sum error" i changed my cmos batteries but steel there is a problem.......is there any problem in my SMPS.....? or mother bord OR my OS is couse?
Every Body Says I'm Fine.
mak1012 is offline
Old 09-02-2007, 12:12 PM   #2 (permalink)
::cyborg::'s Avatar
Default Re: checksum??????
@mak do u hear any beeps if u hear how many?
second thing clean ur ram slots
:)) - KEEP SMILING
::cyborg:: is offline
Old 09-02-2007, 02:18 PM   #3 (permalink)
GUNNING DOWN TEAMS
wizrulz's Avatar
Originally Posted by mak1012
hi,
The most common cause of checksum errors in CMOS is a battery that is losing power. Viruses can also affect CMOS settings, and motherboard problems can also affect the stored values.
Viruses can corrupt the CMOS memory (although they cannot reside in it).
So scan the system with good udated antivirus.
A failing supply can lead to problems with the whole system, and especially motherboard components.
wizrulz is offline
Old 09-02-2007, 11:00 PM   #4 (permalink)
Resident Fanatic
Manshahia's Avatar
Was having the same problem, but changed the battery and now i m happy.
Manshahia is offline
Old 09-02-2007, 11:51 PM   #5 (permalink)
shantanu's Avatar
check your battery port sometimes the pins around loose up and the battery does not work properly
shantanu is offline
