Old 09-02-2007, 02:03 AM   #1 (permalink)
Exclamation Plss help...Which 1 is better???
Hi frnds,
I hve Intel Chipset 845GV Motherboard...n intel P4 2.66 GHz Processor,,,,
I wana to know Which 1 is better regarding performance????---256 DDR @400 MHz Frequency RAM or 384 DDR @266 MHz(128DDR @266MHz + 256DDR @ 266MHz) RAM.....
plsssss help me out......which 1 frm the above is better regarding performance???
Wa8ing 4 ur help...
Regards,
Deepak
dipak15 is offline
Old 09-02-2007, 02:16 AM   #2 (permalink)
Arsenal_Gunners's Avatar
Default Re: Plss help...Which 1 is better???
I think 256mb ddr 400 is better.
(I thought you have written I instead of L in plss..)
Arsenal_Gunners is online now
Old 09-02-2007, 02:32 AM   #3 (permalink)
Thanx Vimal....
its up to u man...how u see...i hve written l not i
dipak15 is offline
Old 09-02-2007, 02:39 AM   #4 (permalink)
You should have posted it to q&a section.
Old 09-02-2007, 02:55 AM   #5 (permalink)
rajasekharan's Avatar
DDR 400 mate . its far better .
Make a day good , and another day good , and another ...a happy lad is "born" from you :)
rajasekharan is offline
Old 09-02-2007, 08:22 AM   #6 (permalink)
nishant_nms's Avatar
and u may even use the 128 stick with 400 Mhz one when need arises too
nishant_nms is offline
Old 09-02-2007, 02:04 PM   #7 (permalink)
Exclamation Re: Plss help...Which 1 is better???
Thnx frnds.....
Actually scenerio is dat I already hve both 128 @266MHz and 256 @ 266MHz...n using both of them 4 last 1 yr...but now my 256 @ 266MHz crashed..... n it is in warranty period....so i can get a replacement 4 it...
So plss help dat whether now i ask my dealer to replace it as 256 DDR @ 266 or 400 MHz.....also i dont think so 256 wid 266MHz come in the market....so by deafault i think my dealer gimme a 256 @ 400MHz RAM....I think so........
So dats y asking which 1 to get frm my dealer 256 DDR @ 266MHz or 256 DDR @ 400MHz.......In case if i 'll get 256 DDR @ 400MHz ,,,,i think my 128 DDR @266MHz...may go to junk yard...as i dont thing 2 RAM's wid diff frequency work together......
So help me frnds finally which 1 to opt??????
Wa8ing
Regard's
Deepak
dipak15 is offline
Old 09-02-2007, 02:05 PM   #8 (permalink)
^^I have found out that your chipset does not support ddr 400.Maximum is ddr 333mhz
http://www.intel.com/products/chipsets/845gv/index.htm
Old 09-02-2007, 02:08 PM   #9 (permalink)
yaa i think so,,,,as it intel chipset 845GV Motherboard....
dipak15 is offline
Old 09-02-2007, 02:13 PM   #10 (permalink)
GUNNING DOWN TEAMS
wizrulz's Avatar
Originally Posted by dipak15
Thnx frnds.....
Wa8ing
Regard's
Deepak
Go here Intel® 845GV Chipset
UR mobo does not supports 400Mhz ram....so no point getting those...
better get 266 mhz ram only..because even if it would had supported 400Mhz ...it would had run at slowest ram on mobo..i.e 266Mhz....and if its replcement i am damn sure that the vendor will no give u 400mhz ram.....and if he gives he will charge u more ..or if doesnt then he is DUMB seller
wizrulz is offline
Old 09-02-2007, 02:19 PM   #11 (permalink)
yaa wizrulz...ya i found that my motherboard nt support 400 mhz on intel portal....but 1 of my frnd hve same motherboard...n recently bought a 256 DDR RAM....on dat there is a sticker mentioning 256 DDR RAM @ 400 MHz...but it still works on his mother board
__________
thanx yaar
dipak15 is offline
Old 09-02-2007, 02:21 PM   #12 (permalink)
GUNNING DOWN TEAMS
wizrulz's Avatar
it will work on the mobo but at max speed of 333mHz ..simple
wizrulz is offline
Old 09-02-2007, 07:50 PM   #13 (permalink)
get 400 mhz one and I assure u that It will work with 266 Mhz module but it will also run with 266 mhz speed. So ask ur dealer for 400 mhz one as replacement
Old 09-02-2007, 08:28 PM   #14 (permalink)
Fast 'N' Furious
topgear's Avatar
I agree
__________
Thats right but I think this will occur some kind of prob as no one prepared for bad luck if the 400 MHz will try run on 333MHz
topgear is offline
Old 09-02-2007, 08:48 PM   #15 (permalink)
^^ It will not happen it is absolutely safe
Old 16-02-2007, 07:45 PM   #16 (permalink)
Fast 'N' Furious
topgear's Avatar
^^^ Well See This:
RAM troubles...
ToPsPeEeD = FaSt BuT StEaDy
topgear is offline
Old 17-02-2007, 03:52 AM   #17 (permalink)
Exclamation Re: Plss help again...Is it better??
Thnx all of u frnd....
Actually the RAM which my vendor has given 2 me as a replacement is labelled as Simtronics 256 DDR @ 333MHz in replacement of my older Hynix 256 DDR Ram,,,,,,
But when I start my PC only with dat Simtronics Ram it shows 266Mhz...
n now pc runs very much fine with 384mb(256+128) of ram.....
But 1 thing I am not clear dat...although my both hynix 128 and Simtronics 256 ram working properly....is it better to run 2 different brand of ram simultaneously???
I didn't said my 2 vendor when he is giving me the replaced RAM of Simtronics...dat I want hynix 256 ram only as my previous one coz i already fed up with late replacement of my ram dat is of 10 days...n if i again
said 2 him this thing...it'll take more time 4 replacement....
So my both hynix 128+Simtronic 256 properly....also they r in warranty period....So frnds help...whether i hve to retain using this configuration or again go to my vendor saying that my old 256 ram is of hynix so gimme only hynix ram....
Wa8ing 4 ur helps...n thanx in advance
dipak15 is offline
Old 17-02-2007, 04:12 AM   #18 (permalink)
caleb's Avatar
Default Re: Plss help again...Is it better??
Depak, although your Simtronics 256 DDR is @ 333MHz your hynix 128 DDR is @ 266MHZ so when you use them together your PC will run at the slowest of the 2 (in other words it will run @ 266MHZ) but if you REMOVE the Hynex 128mb ram and run the PC with ONLY the Simtronics 256 DDR is @ 333MHz you will see that it is running at 333MHZ.
But if you also want the Hynix 128mb in your PC (along with the Simtronics 256 DDR )than you will have to make do with 266MHZ. So the answer to your question is even if your vendor gives you a Hynix 256MB @ 333MHZ you will still face the same problem.
So if you want to be able to run at 333MHZ than BOTH the sticks have to be of the SAME i.e. 333MHZ if not than your PC will run at the slowest of the 2 sticks.
caleb is offline
Old 17-02-2007, 05:28 AM   #19 (permalink)
Learner
Kniwor's Avatar
My suggestion is use the entire ram at 266Mhz, given the amount of ram is less, u will most probably first have problem with amount of ram, and then only will u see a a slowness due to bandwidth. However If u would have asked the same question in another scenario, e.g. 1Gb ram @800Mhz or 1.5Gb ram @533Mhz, I would have said 1Gb ram @800Mhz. But the extra 128Mb will benefit you in you case.
Kniwor is offline
Old 17-02-2007, 08:44 AM   #20 (permalink)
 Macboy
goobimama's Avatar
Me too thinks that get MORE ram than FASTER, at least in your case. Speed matters a lot when it comes to gaming and such, but for regular multitasking the More the merrier...
I'm like a bird... :)
goobimama is offline
Old 17-02-2007, 10:22 AM   #21 (permalink)
Originally Posted by caleb
Depak, ... if you REMOVE the Hynex 128mb ram and run the PC with ONLY the Simtronics 256 DDR is @ 333MHz you will see that it is running at 333MHZ.
Nope on this mobo DDR 400 runs Max at 200mhz
Stick is offline
Old 17-02-2007, 06:10 PM   #22 (permalink)
Unhappy Re: Plss help...Which 1 is better???
thnx 2 all of u frnds.....but wat abt brand name??? ---vendor has given me simtronics ram instead of hynix rams.....And also though simtronics ram is labelled as 256 DDR @333MHz but when i run it alone...it shows only 266MHz,,,,???
__________
thnx caleb but i run my simtronics ram alone also still it is showing 266MHZ though it is labelled as 256DDR @333MHz
dipak15 is offline
