Old 08-02-2007, 10:15 PM   #1 (permalink)
in search of myself
CadCrazy's Avatar
Default Wanna Purchase 2.5' external HDD
I want to purchase 2.5 external HDD. My budget is 2-2.5k. Please suggest me some cheap n best HDD. should i go for HDD+Casing solution.
thanks.......................................
CadCrazy is offline
Old 09-02-2007, 01:29 AM   #2 (permalink)
Waiting for 3 Miracles...
saurav29's Avatar
Default Re: Wanna Purchase 2.5' external HDD
40 gb hitachi , chinese casing ........
saurav29 is offline
Old 09-02-2007, 06:44 PM   #3 (permalink)
in search of myself
CadCrazy's Avatar
Do you have any idea abt the price?????????????
CadCrazy is offline
Old 10-02-2007, 09:45 AM   #4 (permalink)
Let the music play.....
djmykey's Avatar
Hdd rates dunno,
casing u shud get for 550/- or sumthing similar.
djmykey is offline
Old 10-02-2007, 05:16 PM   #5 (permalink)
mera kutch nahi ho sakta
chesss's Avatar
casing would cost you Rs 150 - nehru place
chesss is offline
Old 10-02-2007, 09:12 PM   #6 (permalink)
in search of myself
CadCrazy's Avatar
Price of 40 gb n 80 gb plz
CadCrazy is offline
Old 10-02-2007, 09:16 PM   #7 (permalink)
Gaurav's Avatar
should be around 1500 to 2000
Gaurav is offline
Old 10-02-2007, 09:21 PM   #8 (permalink)
Laptoping
Sourabh's Avatar
2.5" 40GB 5400 RPM Seagate/Hitachi/any other brand cost nearly the same - 2.3-2.5k and you can get the casing for another 300 Rs. Get the connections and formatting done from the vendor itself so that there are no issues later.
Sourabh is offline
Old 11-02-2007, 06:01 PM   #9 (permalink)
nishant_nms's Avatar
Are external casing availabe for normal HDD not the laptop ones?
nishant_nms is offline
Old 11-02-2007, 07:02 PM   #10 (permalink)
in search of myself
CadCrazy's Avatar
Yes these are also available
CadCrazy is offline
Old 12-02-2007, 12:02 AM   #11 (permalink)
^^for how much
Old 12-02-2007, 03:16 AM   #12 (permalink)
40 gb hitachi--- 2450/- chinese casing 150/-
on_the_rocks is offline
Old 13-02-2007, 09:55 AM   #13 (permalink)
in search of myself
CadCrazy's Avatar
Yesterday i purchased 40GB 2.5 inch seagate hdd + Chinese casing for
Rs 2250/- from Nehru Place. The price of 80 gb with casing was Rs 3250.
One guy there purchased transcend casing for around 650/-.
is there any performance benefit if would go for any branded casing ?????
CadCrazy is offline
Old 13-02-2007, 02:05 PM   #14 (permalink)
I donot think so... Life may vary performance i doubt it.. if you buy a SATA Hdd with casing then performance will vary but they are available in only 80gb and 120gb varaints...
Old 13-02-2007, 02:21 PM   #15 (permalink)
shashank4u's Avatar
go for any branded laptop harddisk..40 gb
buy casing which is 150-200 rs..local..no prob with it just a circuit..
my friend has done this ..
u shud get everything around 2500 depending upon the price of harddisk..
Be like a postage stamp-stick to one thing until you get there.
shashank4u is offline
Old 13-02-2007, 07:13 PM   #16 (permalink)
in search of myself
CadCrazy's Avatar
is there any casing avaiable for SATA HDD. And much does it cost (2.5 inch HDD+casing) ?????
CadCrazy is offline
