08-02-2007, 09:09 AM
Which processor to go for ??
hello friends..I am in a bit confusion..Please help me..
I want to upgrade my Mobo as well as the Processor..My budget is around..11K extendable to 12K..for the processor and around 7k for the mobo..
According to me I have these three choices..
1)Intel Core2Duo 1.86 GHz..or any other on the same platform..within the budget
2)AMD Athlon 64 X2 4200+ or any other on the same platform ..within the budget..
3)Pentium D..3.4 GHz
Please suggest me the best Processor in this budget..and also the best compatible motherboard ..(budget for mobo is around 7-8k)..
08-02-2007, 09:51 AM
Re: Which processor to go for ??
Hi,
My suggestion is go for Duel Core 3.4GHz which is around 8k in Mumbai & Asus P5GZ-MX which is around 3600k.If u compare performance of Duel Core 3.4 with Core 2 Duo 1.86,then u can see there is no difference in performance.
Regards,
ThinkDigitReader
"Knowledge Multiplies By Dividing"
08-02-2007, 04:42 PM
Originally Posted by thinkdigitreader
Hi,
thanks for the suggestion but it doesn't seems to be the right combination when the budget is around 12k for the proce and 7k for the mobo..
any better suggestion ..
__________
please suggest me..!!
Reason: Automerged Doublepost
08-02-2007, 04:46 PM
Core 2 Duo E6300 1.86 GHz and an MSI P965 Neo. If anyone thinks that Pentium D performs as fast as Core 2, he/she needs to get his eyes and brains tested.
C2D E8400@3.8, P5N32-E SLI, 2GB Cellshock DDR2 1000(4-4-4), 8800 Ultra SLI, 2.7TB storage, CM Stacker 830, TT 1200W, Dell 2005FPW, Lots of Audio HW.
08-02-2007, 04:53 PM
I think Core 2 Duo 1.86 GHz is around 8k in Kolkata..and what is the price of the mobo..
have you gave the suggestion keeping in mind the budget of 19K in total (proce and mobo)..
E6400 would not be a better option than E6300..??
What about the performance of AMD X2 4200+ against the Core 2 Duo..(E6400 as well as E6300)..
08-02-2007, 04:58 PM
Romeo + Lucifer = ME
go in for a C2D if u can fit it into your budget........or else PD is good enough. What is the main purpose or function of your computer?
Sony Vaio CW26FG
Nokia E 63 + Iphone 3GS
08-02-2007, 05:08 PM
gaming and some simple multimedia..like encoding..etc..
08-02-2007, 05:17 PM
if u are into these stuffs then go in for C2D...but if u run out of budget then even a PD is good enough.
Sony Vaio CW26FG
08-02-2007, 05:21 PM
And what about the mobo..(around 7K)..with good chipset supporting some games for atleast in low settings..
08-02-2007, 05:36 PM
if u go in for PD then u should settle for Intel D102GGC2 for about 4k.......it will suffice all ur needs of gaming( has ati x200 onboard and a pci-e slot for future upgrade)
Sony Vaio CW26FG
08-02-2007, 05:53 PM
If you have a 19k budget, get an E6300 and an asus P5B.
08-02-2007, 10:40 PM
His budget is at max 12k
Sony Vaio CW26FG
08-02-2007, 11:13 PM
Are you blind or don't you know basic arithmetic? He said his budget is 12+7=19  .
08-02-2007, 11:17 PM
Google Bot
c2d e6400 + intel dg965ry or gigabyte ga 965 ds3
08-02-2007, 11:23 PM
Still Shining!
Yah, its a good mobo with lots of features and an ATI chipset. Even games like Doom III, NFS carbon, Half Life 2 plays well in it...Earlier ASUS used to ship a mobo with the x200, but they have now stopped it....
Nokia N86 8MP
08-02-2007, 11:37 PM
DS3 with E6400 won't fit in his budget. G965RY is one pathetic board.
