Old 08-02-2007, 08:05 AM   #1 (permalink)
Default Occasional Booting problem
Hi,
I have a couple years old PC at home... When I boot it after nonusage for a day or so, it has trouble starting up.... I have to press the power button in the front panel and the SMPS power switch in the back a few times before it starts... Usually, I use it in the mornings and nights... If I use it both times of the day, generally there is no problem... If I skip one session, sometimes there is starting problem, and if I skip a day or two, the problem appears...
Any idea what could be the cause of the problem and how to resolve it?
Arun
sakumar79 is offline
Old 11-02-2007, 12:31 AM   #2 (permalink)
Deadman Walking
Batistabomb's Avatar
Default Re: Occasional Booting problem
It was clearly understanding that u r SMPS needs repair,so hurry or once clean u r RAM
Batistabomb is offline
Old 11-02-2007, 12:59 AM   #3 (permalink)
Arsenal_Gunners's Avatar
Fix the Smps(not yourself)
Arsenal_Gunners is online now
Old 11-02-2007, 02:22 PM   #4 (permalink)
Jack Sparrow
joey_182's Avatar
clean ur RAM slots and check for supply cable..if it requires to be cleaned up...
KHAO PIYO TE AISH KRO!!
http://twitter.com/puneetshrma
joey_182 is offline
Old 11-02-2007, 05:56 PM   #5 (permalink)
nishant_nms's Avatar
clean ur PC. Test ur ram using memtest and if still problem presists get a new SMPS
nishant_nms is offline
