Help...Computer is restarting while installing Windows XP...
Hi,
One of my friend's computer is restarting while installing windows XP(where F8 is required to press I Agree).....I have also tried with different Cds...
I have tried to install windows 95 and 98 SE.....both are installing n working properly.
Computer specifications are-
P III 733Mhz
128 MB SD RAM 133Mhz
20GB Segate Harddrive
LG CD-Rom
Re: Help...Computer is restarting while installing Windows XP...
Originally Posted by debaisaindian
Hi,
P III 733Mhz 128 MB SD RAM 133Mhz
LG CD-Rom
Please suggest what should be the problem???
DUde u have 128MB...and u wanna run XP..even if it installs properly it will eventually restart due to less ram >>...i used to have problem with xp even with 192 mb ram
Try changing the CD Drive or temporarily install somebody else’s CD ROM drive & see if it works.
I had similar problem of XP installation suddenly restarting during initial ‘copying file’ DOS screen installation, and this trick (changing CD Drive)worked for me. I don’t know why but it worked.
Alternatively xcopy the entire XP CD contents to some other partition on Hard Drive and run ../I386/WINNT.EXE from there. The installation will be very very slow and will take more than 2 - 3 hours to complete, but if it works, then there would have been some issue with CD ROM drive or errors during CD ROM Read while installing from the CD
