Old 07-02-2007, 06:30 AM   #1 (permalink)
No pain....No gain
john_the_ultimate's Avatar
Default Suggest a laptop for basic purpose.
I want to buy a laptop for basic purpose, msoffice, web browsing etc. So please could some one suggest the cheapest laptop. Haven't set any budget but will decide according to your suggestions.
john_the_ultimate is offline
Old 07-02-2007, 06:55 AM   #2 (permalink)
Default Re: Suggest a laptop for basic purpose.
check out laptops offered by hcl....they have a series of low cost laptops...which are for basic use ......
tehnogeek is offline
Old 07-02-2007, 09:23 AM   #3 (permalink)
kumarmohit's Avatar
Lenovo C200
Review : - http://www.notebookreview.com/defaul...ew=Lenovo+C200
kumarmohit is offline
Old 07-02-2007, 01:53 PM   #4 (permalink)
premsharma's Avatar
HCL have laptos below 30,000 with 1GB RAM & DVD writer but celeron based. If Celeron is not a problem, then these are the cheapest. Next is Acers celeron based or AMD based laptops.
premsharma is offline
Old 08-02-2007, 01:22 AM   #5 (permalink)
No pain....No gain
Thanks guyz will check out the suggestions..............any other options.
Old 08-02-2007, 07:14 AM   #6 (permalink)
Recently I happened to see an advertisement of ACi laptops of a wide range starting from one for Rs.19000/- to very costly ones. But the one for 19K is one with Via processor and most others with Intel ones. So you may consider their products also.
V.Prem Kumar
janitha is offline
Old 09-02-2007, 06:19 AM   #7 (permalink)
No pain....No gain
@janitha
Thanks for the info. Will look into it.
