Old 06-02-2007, 08:51 PM   #1 (permalink)
kool's Avatar
Question Very Fast Mouse...... how2slow???? ~!~!~
Dear friends,
I've winXP PRO SP2 , last month i bought "SUPERCOMP"
optical mouse which has 800 dpi resolutiuon. Now my mouse is working too fast, whenever i click once on any icon it automatically clicked twice-thrice.
For example, when i click once on NEW TAB under opera/firefox/ie7 then sometime it opens 2-3 Tabs instead of one. When i click on [X] close button of any opened windows then automatically also closed other windows which is just behind that window. After this problem i reduced sample rate to 80 and disabled fast intialization under mouse setting. But still i've problem. Its PS/2. Can anyone tell me whats the problem? And how can i solve it??
►► ◄◄ :smile::smile:
kool is offline
Old 06-02-2007, 09:37 PM   #2 (permalink)
Default Re: Very Fast Mouse...... how2slow???? ~!~!~
control panel> mouse properties will give u options to set the speed.
ranjan2001 is offline
Old 06-02-2007, 09:41 PM   #3 (permalink)
Šupər♂ - 超人
koolbluez's Avatar
Yup... CtrlPnl -> Mouse Properties -> DoubleClick speed... reduce it and test in box on right.
That'll solve ur prob.
koolbluez is offline
Old 06-02-2007, 09:48 PM   #4 (permalink)
AJJU
azzu's Avatar
hey mr kool whose in there in ur AVAVTAAR
I love and Live to Design
azzu is offline
Old 06-02-2007, 10:12 PM   #5 (permalink)
Šupər♂ - 超人
koolbluez's Avatar
That i'ld like to add... is not Mr.Kool... but a Telugu starlet by the name of Allu Arjun... upcomin star, nephew of Chiranjeevi, Telugu's leading actor.
Old 07-02-2007, 12:06 PM   #6 (permalink)
kool's Avatar
i've already decreased speed of double click to lowest!!
kool is offline
Old 07-02-2007, 12:34 PM   #7 (permalink)
Šupər♂ - 超人
koolbluez's Avatar
Copy this data in notepad and put the file extension as .reg
Windows Registry Editor Version 5.00
[HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Explorer\Advanced]
"UseDoubleClickTimer"="1"
[HKEY_CURRENT_USER\Control Panel\Mouse]
"DoubleClickHeight"="4"
"DoubleClickWidth"="4"
"DoubleClickSpeed"="450"
Apply the registry file thus made.
Or reinstall mouse drivers...
Old 07-02-2007, 05:42 PM   #8 (permalink)
kool's Avatar
still have prob :X
kool is offline
Old 07-02-2007, 06:25 PM   #9 (permalink)
Nasty virus hit......can only work in safe mode, need urgent help
I had a similar issue with my mouse read the above thread & see if that applicable in ur case, I had a major trouble for 2-3 days due to the same problem
Old 07-02-2007, 07:23 PM   #10 (permalink)
Šupər♂ - 超人
koolbluez's Avatar
Tell us if u got the prob solved. And how u did it? Might help 4 others.
Old 07-02-2007, 07:40 PM   #11 (permalink)
I gave the link to that thread, not sure if its applicable in his case.
Old 07-02-2007, 07:43 PM   #12 (permalink)
madmax_tt's Avatar
might be your mouse pad..........lolzzzz
madmax_tt is offline
Old 07-02-2007, 11:18 PM   #13 (permalink)
kool's Avatar
whats the relation between pad with optical mouse??
By the way....... still i've problem. i think this happened after installing TUNE UP UTLITIES 2007. just check out captured pic.. And also of regedit (that said by koolbluez)
kool is offline
Old 07-02-2007, 11:38 PM   #14 (permalink)
kool's Avatar
check..........
kool is offline
Old 08-02-2007, 12:32 AM   #15 (permalink)
Coming back to life ..
it_waaznt_me's Avatar
Try lowering Mouse Sensitivity from 12 to say 8 ..
[Edit] You dont have to lower Mouse Double Click speed .. You have to increase it .. Make it something around 500 to 600 .. On my system the slowest speed has the value of 900 and the fastest speed has value of 200 ..
And I wait without you ...
With or without you ..
Batty = Too Busy Now !!!
it_waaznt_me is offline
Old 08-02-2007, 08:21 AM   #16 (permalink)
Šupər♂ - 超人
koolbluez's Avatar
If u r that fast a double-clickr.. then increase the speed i.e.
"DoubleClickSpeed"="200"
But 450 is fair enuf. If it doesnt work with this.. then might b something wrong with ur mouse (clean the mid-button spaces, mayb they stick 2 each other or so) or mayb some corrupt installation. U sure u've no viruses in there.
Did u try changing the mouse? Try trouble-shooting by pin-pointin the culprit. Remove & test them one-by-one.
Old 08-02-2007, 09:56 AM   #17 (permalink)
kool's Avatar
ya.... i'm sure no virus!!!
whats this?? PIN POINTING?
kool is offline
Old 08-02-2007, 10:43 AM   #18 (permalink)
Livin' in the ghetto
AshishSharma's Avatar
Hmmm maybe u can scare the mouse my pointing a pin towards it ... Something like... " U better slow down or I'll poke this pin into you"
On the serious note it's typical that the Windows Mouse settings have no effect in case of Optical Mouse. It's obviously the drivers installed with the mouse riding the roost, check the manufacturer website to see if new drivers are available.
~.~ Never argue with idiots, they just drag you down to their level then beat you with experience. ~.~
AshishSharma is offline
Old 08-02-2007, 12:51 PM   #19 (permalink)
kool's Avatar
can anyonr tell the update site of SUPERCOMP?
kool is offline
Old 08-02-2007, 01:14 PM   #20 (permalink)
Wire muncher!
infra_red_dude's Avatar
hmmmm.... did u install any drivers when u first install the mouse? try uninstalling the mouse, removing it from the port. restart windows widout mouse once. then switch off, connect mouse and boot into windows again. this time try a generic driver for your mouse. mebbe a generic microsoft mouse driver will do. report back.
infra_red_dude is offline
Old 08-02-2007, 01:26 PM   #21 (permalink)
kool's Avatar
no i didn't installed any driver for mouse. its plug n play type!!
kool is offline
Old 08-02-2007, 01:42 PM   #22 (permalink)
kool's Avatar
its microsoft compatible driver!
kool is offline
Old 17-02-2007, 12:21 PM   #23 (permalink)
Hey dude did you manage to get the issue resolved ?
Old 17-02-2007, 07:45 PM   #24 (permalink)
kool's Avatar
Angry Re: Very Fast Mouse...... how2slow???? ~!~!~
No still i've problem. Today i re-installed my winXP by formatting C: drive, after re-installation mouse worked well, but after installation of autopatcher, tune-up utilities2007 again same problem.
My mouse gives "one" click sound, but it acts as double click in windows. But sometime it works normal.
kool is offline
Old 04-03-2007, 09:27 AM   #25 (permalink)
Šupər♂ - 超人
koolbluez's Avatar
Now.. I've the prob... a click on my x close button.. all my tabs close!!!! Happens everywhere. A single click on a file, opens it. Ya.. I checked Folder options... double click should open the file. Rouge clicks getting done when I do just a single one. Big prob. Mine is a samsung optical mouse. Long time. No prob. Might not b its prob too. When re-installed windows... prob doesn't exist for some dayz. Then all of a sudden it comes. Virus!?! Any idea.... my updated AVG didn't detect it.
Didn't want to make a new thread on the same... so continued here.
Help...
A single click on my mouse acts like multiple clicks. So fast. Checked registry settings. Most r intact. Is it a virus or corrupt sw? Or is it dust between & under my mouse buttons!!!
Biggies.. help please. Any1 got this prob & successfully dealt with it?
Dar lagta hai ek click maarne ke liye! eek...
__________
Cleaned my mouse buttons, below & side everywhere. Prob seems to have disappeared temp... Hope this is the reason. Does an optical mouse too need cleanin!!! kya zamaana aa gaya?
__________
Kudos to my dear friend... tech_mastermind for the fast replies.
He asked me to change my report rates(in advanced mouse hardware properties) to 100(I put it to 200 earlier for smoother gameplay ) & enable enhanced pointer precision(not changed on my rig). Hope it works. Thnx bro. Posted it here as some one else might benefit from it.
"ll confirm if it's the prob solution. Thnx again.
__________
Kool.... do ya think this is ur prob too...?
Old 04-03-2007, 11:53 AM   #26 (permalink)
a_g = JPKN
s18000rpm's Avatar
just as a precaution post a hijack This log
ASUS K53SV SX520D + BF3
s18000rpm is offline
Old 04-03-2007, 12:11 PM   #27 (permalink)
Arsenal_Gunners's Avatar
WTF it must be a hardware problem.Are you using a cheap sh1t muse;
Arsenal_Gunners is online now
Old 04-03-2007, 12:11 PM   #28 (permalink)
Distinguished Member
anandk's Avatar
great 2 c ur issue resolved. nice reply tech_mastermind !
ya, else ^ check out ur hjt.
> www.TheWindowsClub.com <
= www.WinVistaClub.com =
Microsoft® MVP
anandk is offline
