Old 06-02-2007, 05:10 PM   #1 (permalink)
Default trouble with wdd 200 gb sata hdd
hi all...
i recently bought a wdd 200 gb sata hdd and used the lifeguard tool from the wdd site to format and partition it...made 5 partitions of 10, 10, 20, 20 ,130 gbs...installed xp and then upgraded to xp sp2
however now, i want to reinstall windows, it just shows one drive of 189 gbs ...not recognisable by windows...wat do i do?
azad is offline
Old 06-02-2007, 08:06 PM   #2 (permalink)
GUNNING DOWN TEAMS
wizrulz's Avatar
Default Re: trouble with wdd 200 gb sata hdd
Originally Posted by azad
hi all...
is all data also lost...as its hsowing 189gb ???
wizrulz is offline
Old 11-02-2007, 07:16 PM   #3 (permalink)
no..the data is not lost..its all fine...it shows evrything proper when i am in windows..the problem only occurs when i tried to reinstall windows...
azad is offline
