Originally Posted by codename_romeo
isnt there a method 2 get ur drives working back in dma mode instead of PIO?
OOUCH....... For this you installed windows again..........
First Case Scenario:
DUDE remember this ........ if you are using Intel Based motherboard very easy solution Install Application Accelerator Plus...... Aka IDE drivers for your Motherboard it will select the best mode........
Second Case Scenario:
USE a 80 pin conductor cable the hard colorful end type cable for IDE devices it will select the best mode possible.... Donot rely on old cables if these things occur they may be not working fine (I once got message for my 80 gb IDE hdd Smart capability bad.....when i went to service centre they said no problems in hdd.... again i connected it to PC again HDD samrt capability bad working no problems .... with both Optical device and HDD on same IDE cable.. i Noticed that my HDD was running at UDMA 2 and optical drive DW2 mode ... Replaced the cable .......Problem Solved.........
Third Case Scenario:
actually try this first...........
go to device manager aka(rclk.. My computer>properties > Device manager..
The setting you require are under IDE/ATA/ATAPI controllers
Select your channel primary---> IDE 1 Or Secondary IDE 2 right clk and select advanced options... Set it to DMA if available.......
for both device..........
Restart........... The problem will be solved ....... At least should be solved in theory........
If not what the heck perhaps you did the right thing..... loose the copy of windows......... But it a hassel to bakup data and lie to those Customer care guys every time you try activating the windows..........
or may be not everybody requires to activate the windows................
Peace
Raj
