Old 05-02-2007, 10:35 AM   #1 (permalink)
rajwansh2003's Avatar
Exclamation All about processor
As i am new guy and really confused about processor can any one tell me about processor in deep. What is Pentium D, HT, Core 2 Duo,M,celeron, Quatra and etc.........
Anupam
rajwansh2003 is offline
Old 05-02-2007, 11:03 AM   #2 (permalink)
thinkdigitreader's Avatar
Lightbulb Re: All about processor
Hi,
Please check for more information
Pentium D processor:
http://www.intel.com/products/proces...um_d/index.htm
HT:
http://syndication.intel.com/Distrib...GF1_0055017001
Core 2 duo:
http://www.intel.com/products/proces...2duo/index.htm
M:
http://www.intel.com/products/proces...iumm/index.htm
Celeron:
http://www.intel.com/support/processors/celeron/
Regards,
ThinkDigitReader
"Knowledge Multiplies By Dividing"
thinkdigitreader is offline
Old 05-02-2007, 11:06 AM   #3 (permalink)
santu_29's Avatar
Default Re: All about processor
Pentium D is a series of microprocessors introduced by Intel at the Spring 2005 Intel Developer Forum. A Pentium D chip consists of two Pentium 4 Prescott processors on a single die.
Hyper-Threading Technology (HTT) is Intel's trademark for their implementation of the simultaneous multithreading technology on the Pentium 4 microarchitecture. It is basically a more advanced form of Super-threading that first debuted on the Intel Xeon processors and was later added to Pentium 4 processors. The technology improves processor performance under certain workloads by providing useful work for execution units that would otherwise be idle, for example during a cache miss.
A dual-core(or core 2 duo) CPU combines two independent processors and their respective caches and cache controllers onto a single silicon chip, or integrated circuit. IBM's POWER4 was the first microprocessor to incorporate 2-cores on a single die. Various dual-core CPUs are being developed by companies such as Motorola, Intel and AMD, and are scheduled to appear in consumer products in 2005.
Celeron, A brand name for a line of Intel microprocessors introduced in June, 1998. Celeron chips are based on the same P6 architecture as the Pentium II microprocessor, but are designed for low-cost PCs. They run at somewhat lower clock speeds (266 and 300 MHz) and are not as expandable as Pentium II microprocessors.
Unless you have a dream, you are not going to achieve anything in life.
Shoot for the moon, even if you miss, youll fall in the stars.
******************ÏMPÕ§§ÏßL£ ϧ ÑÕTHÏÑG ******************
santu_29 is offline
