As of now 2 sata hdd are connected on port 1 & port 6, I want to chnage ut to port 1 & port 2 but the hdd is dedected on the port in BIOS & also by windows in device manager but does not show up in Windows Expolorer.
Do I need to do something else to get them showing in windows explorer?
Ok understood it needs importing, reconnected that on 2nd port started up but strangely now its showing on its own.
Solved the problem............Thanks
