Re: intel/amd
forget the budget im still working on the logistics (doesnt mean il get the hi-fi system) ... i wanna know which is a better option coz b4 c2d ... it was amd as the obvious choice ... is amd's answer tot he c2d good enough ...
my way know wats the best option and then see wat can b compromised
http://beingmanan.com
