Old 01-02-2007, 02:04 PM   #1 (permalink)
Unhappy Pentium 4 Extreme edition or dual core
Hi friends can anyone tell me the price of a Pentium 4 3.x ghz Extreme edition with hyperthreading, and the value of its L2 and L3 cache.
If I have the option Between (Pentium 4 extreme edition with HT) and (Pentium D processor).Which one should i opt, Keeping GAMING as the primary need.please Help.
Tsunami is offline
Old 01-02-2007, 02:09 PM   #2 (permalink)
Default Re: Pentium 4 Extreme edition or dual core
Neither.... get core 2 duo.
C2D E8400@3.8, P5N32-E SLI, 2GB Cellshock DDR2 1000(4-4-4), 8800 Ultra SLI, 2.7TB storage, CM Stacker 830, TT 1200W, Dell 2005FPW, Lots of Audio HW.
Ch@0s is offline
Old 01-02-2007, 02:19 PM   #3 (permalink)
premsharma's Avatar
It si very easy to recomend C2D to every one. Everybody like you can not go on buying spree, budgeting limitations & many other factors.
Instead cotribute to the comparison of P4 & PD and clear the doubts of many other wanting to know this.
premsharma is offline
Old 01-02-2007, 02:44 PM   #4 (permalink)
18 Till I Die............
Wouldn't AMD be better in that range then? Tsunami if you can mention what budget you can have then people can suggest you what to go for.
http://www.bash.org/?258908
mehulved is offline
Old 01-02-2007, 04:21 PM   #5 (permalink)
Google Bot
Pathik's Avatar
man pls pls evy1 jus mention the max budget... so that u can get appropriate answers...
Pathik is offline
Old 01-02-2007, 05:48 PM   #6 (permalink)
Host4Cheap.org
Sukhdeep Singh's Avatar
If you are tight on Budget for Core 2 Duo, dont go for Intel Then....AMD is better option
http://www.host4cheap.org/
Sukhdeep Singh is offline
Old 01-02-2007, 06:01 PM   #7 (permalink)
He's talking about a Pentium Extreme edition... that exactly aint cheap is it? He wants a CPU for gaming and he's not mentioned his budget. How on earth can you infer that he's budget constrained? I'm just pointing him to the right direction.
Ch@0s is offline
Old 01-02-2007, 08:38 PM   #8 (permalink)
SO what the judgement which one is better i too will like to know... Not intrested in investing in C2D yet....
on_the_rocks is offline
Old 02-02-2007, 11:34 PM   #9 (permalink)
Gaurav's Avatar
my vote goes to pentium 4 extreme edition, better than pentium D as compared to price and performance.
Gaurav is offline
Old 03-02-2007, 05:07 AM   #10 (permalink)
premsharma's Avatar
Cool Re: Pentium 4 Extreme edition or dual core
That is fine but still no one on the comparison of P4 EE & PD. Even I am looking for these answers. I don't find any diffrence in performance in P4 EE & PD. Then was PD a gimmick by Intel matchup with AMD
Old 10-02-2007, 08:10 PM   #11 (permalink)
Unhappy Re: Pentium 4 Extreme edition or dual core
Hi all, Premsharma is correct , i have my budget limited to 4.5 or max 5K..so no question of c2d ,though i know very well that it is the bst.and sadly no genuine reply to my quey...
Tsunami is offline
Old 10-02-2007, 08:35 PM   #12 (permalink)
Still in war with allies
ssdivisiongermany1933's Avatar
Don't go for P4 now on , they are crap now
If u tight on budget than AMD 3800+ is best solution , cheap and good performance
ssdivisiongermany1933 is online now
Old 10-02-2007, 10:43 PM   #13 (permalink)
Google Bot
Pathik's Avatar
get a pentium D... PD 820 2.8ghz
Pathik is offline
Old 10-02-2007, 11:50 PM   #14 (permalink)
Wire muncher!
infra_red_dude's Avatar
well for ~5k even i'd suggest something in the range of 3800+. if u can't get c2d, get this one. simple, if its not c2d its amd athlon. price to perf ratio is just tooooo high for p4 range! not worth it!
infra_red_dude is offline
Old 10-02-2007, 11:59 PM   #15 (permalink)
shantanu's Avatar
3800+ is not in ~5k range
shantanu is offline
Old 11-02-2007, 12:55 AM   #16 (permalink)
Wire muncher!
i'm not specifically pointing at 3800+. "something in that range" my aim was to tell the poster to get the max proc from the amd stables widin his budget rather than go for pentium range.
Old 11-02-2007, 01:14 AM   #17 (permalink)
shantanu's Avatar
ok Buddy!! and i also just cleared it a bit , yeah he must get the best in his price range
shantanu is offline
Old 11-02-2007, 02:00 AM   #18 (permalink)
A friend just purchased an X2 3600+ brisbane core CPU today for 5200 bux. Thats the 65nm AMD64, 1.9GHz, 512x2KB cache. Thats easily the best deal around.
Ch@0s is offline
Old 11-02-2007, 01:37 PM   #19 (permalink)
rajasekharan's Avatar
for 5k
get a p4 2.8
dont think of AMD . u cant get any that beats P4 at 5k range (board +proc).
so invest the entire 5k on a p4 proc....
Make a day good , and another day good , and another ...a happy lad is "born" from you :)
rajasekharan is offline
Old 11-02-2007, 02:13 PM   #20 (permalink)
Jack Sparrow
joey_182's Avatar
yes get the PD....As ur primary need is gaming so plz dont go for AMD....
for gaming intel last longs....
KHAO PIYO TE AISH KRO!!
http://twitter.com/puneetshrma
joey_182 is offline
Old 11-02-2007, 04:01 PM   #21 (permalink)
Wire muncher!
Originally Posted by rajasekharan
for 5k
get a p4 2.8
i beg to differ. there is no comparison between p4 2.8 dual core or PD wid x2 3600+!!!!! i dun think its wise to invest anything on the pentium range! if u can afford get c2d otherwise get the athlon x2 depending on ur budget. imho the binary choice wud be the best decision depending on budget.
Old 11-02-2007, 04:32 PM   #22 (permalink)
mera kutch nahi ho sakta
chesss's Avatar
Ch@OS is right go for AMD X2 3600/3800 if you are getting it < 5500
chesss is offline
Old 11-02-2007, 05:55 PM   #23 (permalink)
nishant_nms's Avatar
Pentium D is a crap never go for it
nishant_nms is offline
Old 11-02-2007, 07:14 PM   #24 (permalink)
will X2 3600+ brisbane core CPU work on an Asus A8NE motherboard(939 pin, nforce 4 ultra)
__________
Yeah Intel lasts long in gaming
(if u never play games)
samanvya_ad is offline
Old 12-02-2007, 01:19 AM   #25 (permalink)
Wire muncher!
the brisbane core uses socket am2 (940 pins). so if the board is bases on 939pins, it surely won't fit in there!!
Old 12-02-2007, 01:25 AM   #26 (permalink)
__________
If you are lucky, you can still find the older manchester 3800 X2 socket 939 CPU. Be ready to pay around 8-9k however for it.
Ch@0s is offline
Old 12-02-2007, 01:29 AM   #27 (permalink)
Wire muncher!
^^^ no point in paying ~8-9k. it wud make sense to go in for c2d if u are ready to spend in that range.
Old 12-02-2007, 01:32 AM   #28 (permalink)
premsharma's Avatar
Lasts long ???? Untill you play any game. Infact Intel should be thankful to ATI for 101 & 102 motherboards. With those mobos atleast some games can be played otherwise intel are all crap processor till C2D and mobos almost all.
Old 12-02-2007, 03:04 AM   #29 (permalink)
Donot know about the price performance ratio between AMD and Intel ..... But can surely vouch for intel if you considering Value for money....... In the sense that....... Overall intel boards have a better driver/ BIOS support then AMD... So they kinda excel in this field as their drivers are updated more frequently than AMD's.... There are so many types of AMD processors (athlon, sempron, thunderbird sledgehammer, duron ,turin ,operaton and what not....in market and to get a corresponding board is a hassel if your board burns out.. you will be in trouble as they are only readily available with cpu only and i know just a very little people who will stock an AMD board you see Bad for Business.......
Besides if you try to sell an AMD board and cpu then you will be in for a surprise a there are a very little or no takers for AMD !!!!!!! Specifically Think like that not many people in this forum will buy it as there will be a faster AMD ready to be taken for not much price.... which most people can afford... Now think of the real people who buy secondhand stuff.... reasons can be any just playing safe.... saving money and do not need a killer these are the people who do not even know about AMD........
I am just giving you a market perspective... Of course both will get the work done for you....... the choice is that how long you wanna stick with your system....???
Old 12-02-2007, 03:29 AM   #30 (permalink)
^^Obviously you have no brains. First of all AMD doesn't provide any drivers. Its the chipset maker that does. If you used a shitty via or sis chipset, then well thats why you are cribbing. Secondly there are only two types of CPUs in the market from AMD... Athlon 64 and Sempron and both run on socket am2. Thirdly every single vendor sells AMD. Infact 50% of assembled systems my dealer sells are AMDs. Finally about resale value... who buys PC components with resale value in mind . It has to be sold as junk no matter AMD or Intel heh. Fact is if one has money, spend on Intel Core 2 Duo which no doubt is the best CPU in the market right now. If one is on a budget, get an AMD athlon x2. Whatever the case, Pentium 4 and D are ridiculously slow and hot and not worth anyone's cash unless he/she has no brains like you.
Ch@0s is offline
